<~----> Heatsink Review.. AkG or SKY Please Comment - Page 2 - Hardware Canucks
Old August 5, 2009, 01:26 PM
stoanee's Avatar
Testing right now...the I7 seems to be a hot running beast.
heatware
Old August 5, 2009, 01:28 PM
Well at first I was scared of opening this thread, glad I did though.. lots of good questions..
Thanks SKY, I did read that they lapped, no idea how I just forgot.. Plus flat vs vertical..
Just like Metaphor I'm also curious on the results they achieved by testing the heatsinks vertically.. hmmm..
Old August 5, 2009, 01:32 PM
SKYMTL's Avatar
HardwareCanuck Review Editor
This is why we recommend reading multiple reviews. Olin's testing methodology will return different results from ours just like others may agree with one or the other.
As for the lapping, I believe it is the CPU which was lapped and the Thor's Hammer we received had a base with the quality of a $2 prostitute.
On a side note, we WILL be moving to vertical testing as we feel it gives a more accurate representation of what the end user will experience.
Old August 5, 2009, 01:37 PM
CMetaphor's Avatar
Quadfather
So... it Does make a difference? Ha ha! I feel accomplished somehow since I might actually be right, lol.
Old August 5, 2009, 01:39 PM
burebista's Avatar
Those result looks more logical. I still don't understand what's up with Thor Hammer next to TRUE and from our tests 10X is on par with Megahalems and TRUE lapped and modded (of course I spoke for maximum heat output and same fans).
Old August 5, 2009, 01:42 PM
SKYMTL's Avatar
As I said, every review will return different results. There is NOTHING "logical" about benchmarking.
Old August 5, 2009, 02:06 PM
burebista's Avatar
Of course EVERYTHING is logical if test conditions are the same for all heatsinks. Same ambient temperature, same RPM fan, same testbed with same CPU with frequency/Vcore, same TIM, same pressure at mounting and if it's possible lapping for both IHS and heatsink base (but last one is for enthusiasts and perfectionists). :)
Then you'll have just one variable: how good heatsink is engineered.
Old August 5, 2009, 02:24 PM
and no life... Honestly, it would take forever, and you wouldn't even have the same variable at home.
Back up - Ebay (Inik1) or Heatware
  #19 (permalink)
Old August 5, 2009, 09:58 PM
burebista's Avatar
I have a word: if you want to do something do it right or don't do it.
Fortunately I have a friend which is obsessed by comparing TRUE vs. anything else and those are his test conditions. I have complete trust in what's he's doing because it do it from passion and with his money so what he get is what he say.
Any other tests from net are just informative for me but I'm eagerly waiting new testing methodology here on HWC.
  #20 (permalink)
Old August 5, 2009, 11:31 PM
Benchmarkreviews tested the 10X only in stock configuration and that only shows how lame the stock fan is. Their testing is fine and you would've recorded a similar result if you'd have tested the Megahalems with the 212+ fan. Ideal tests would require a perfectly flat IHS and an impecable heatsink base. Lapping the CPU takes one variable out of the equation and should definitely help coolers with very good bases.
A good testing methodology doesn't take years but a few hours and willingness to make it right. ATM your tests are very 'manufacturer friendly' because there are many coolers spread within a couple of degrees of eachother. If you cranck up the voltage and consequently increase the TDP you should get greater differences. My personal opinion is you should be testing at around 80 oC for increased accuracy.
In the end everyone reading reviews on the internets should take them with a bottle of salty water if they see HDT heatsinks beating everything.
AKG K518DJ anyone use them? Dashock Audio 1 January 27, 2009 08:22 AM
AKG headphones! Cptn Vortex Audio 1 January 11, 2009 05:32 PM
AKG K702 or Senn HD595? Bojamijams Audio 10 December 16, 2008 06:17 PM
Noctua NH-U9B Low Noise Heatsink Review Hardware Canucks Air Cooling 0 April 30, 2008 09:24 AM
Cooljag Falcon 92-Cu Heatsink Review by FrostyTech Babrbarossa Reviews & Articles from the Web 5 May 22, 2007 05:03 PM
