Originally Posted by 486 Direct Vendetta to push air to the back, it will bring down temps by 0.5 degree. |
How? Proof? It's interesting how everyone has a different opinion on physics. But in general, the less turns and curves air has to make the smoother the airflow... So why make it enter horizontally from the bottom front of the case, then have it go up then horizontal
again and out the back of the case? Oh, and at the same time the air entering the HSF is fighting away from the top exhaust fan? I don't understand that logic... But here's some of my own:
- Hot air moves upwards.
- Air flows the most easily with as little resistance and as little turning as possible
In his setup, cool air enters from the "bottom" of the motherboard section in his case, so cool air passes directly on top and bottom of his video card. Obviously the air that goes below the card will be pulled through it and expelled out the back of the case. The cool air above the card will do a slight curve upwards and go directly through the hsf, warm up, then continue upwards naturally through fan-assisted convection.
... all that to say I think his orientation, and temperatures, are fine IMO.
