Old August 4, 2009, 10:52 PM
Default Help with ocz vendetta2 on i7 rig
I'm quite new to the heatsink world, so i decided to work with an ocz vendetta 2 for my i7 rig, however it was too confusing for me (mostly because i wasn't sure what i was doing half the time) and i hit rock bottom.
After mounting the heatsink and fan for about 4 hours, the temps are still ..the same!
45 on idle and about 75 on full load. I'm worried i mounted it wrong, and now the computer just locks up randomly or while on load (whole screen stays still, and NOTHING moves)
Any ideas on what went horribly wrong? thanks in advance!
http://img22.imageshack.us/img22/6762/img0887h.jpg (front of heatsink)
http://img43.imageshack.us/img43/7117/img0897w.jpg (backplate of mobo w/ i7 attachment for vendetta)
http://img25.imageshack.us/img25/2752/img0893vzd.jpg (whole rig)
*edit* the instructions from the packaging for the LGA1366 attachment wasn't very discriptive in my case..i hope i didn't do anything wrong..
Old August 4, 2009, 11:00 PM
You have it facing the wrong way.
Fan should be blowing to rear of case.
Old August 4, 2009, 11:04 PM
oh man, another re-do..i think i'm going to end up breaking the mobo soon =/
Old August 4, 2009, 11:46 PM
burebista's Avatar
How did you apply TIM? For HDT heatsinks is a particular procedure.
Old August 4, 2009, 11:54 PM
artistpavel's Avatar
No need to change orientation, you have exhaust fan on top, so it sucks hot air nicely. Vendetta 2 is a killer heat sink, you should be in 30s on idle, have you applied thermal paste between CPU and bottom of heat sink? It's a substance that transfers heat from processor to cooler itself.
х58forLife
Old August 5, 2009, 12:26 AM
i have, however i think i put too much. >_<" i guess i have to take off the whole thing again..i have work thoguh, will update tomorrow night!
Old August 5, 2009, 04:57 AM
OmegaRED's Avatar
I've got mine blowing out the top and it does seem to help the temps a bit.
E-Penis Specs:
Coolermaster Cosmos II \\ Intel i5 2500K@4.8ghz \\ Gigabyte PA67 UD7\\ MSI Twin Frozr GTX 680 SLI \\Corsair Vengeance 8GB LP \\ Seasonic Platinum 1000W \\ X-Fi Titanium HD \\ OCZ Vertez 3 120GB \\ RAID 0 Seagate Barracuda 1TB SATA6G 64MB \\ Samsung 27" 3D LED Monitor \\ Logitech G5 \\ Logitech G-15 Keyboard \\ Logitech Z-5500 \\ Sennheiser 595 \\ Windows 7 x64
Old August 5, 2009, 04:10 PM
Dar_ell's Avatar
I also have mine blowing the hot air out to the top, accidently i made my rear fan blow air in...it dropped my temps by 2c so i was like uhh...OK!
"My brother is dead. He's not here Anymore. But on my back, and in my heart...He lives on in me. I will make a hole through heaven itself, even if that hole becomes my grave. As long as I break through, I will be victorious.Who the **** do you think I am?"
Old August 5, 2009, 04:38 PM
stoanee's Avatar
Best orientation is through to the back of the case. Make sure your fan is pointed the right way, blowing through the heatsink. Reseat if you have to.
heatware
Old August 5, 2009, 09:39 PM
However, now my computer froze and black screens when i boot up.
oh man. what a journey
[FS] OCZ Vertex 30GB SSD, OCZ 3GB Triple Channel RAM Dave510 Buy/Sell & Trade 9 May 25, 2009 03:58 PM
[FS] OCZ Vendetta2 Cooler norfolk Buy/Sell & Trade 1 February 21, 2009 08:41 AM
[FS] Gaming Rig E6300 3.0GHz, 8800 GTS, 2GB OCZ Gold,250GB HD, Windows XP Pro,Antec 300 riflepwnage Buy/Sell & Trade 1 February 18, 2009 12:45 PM
Vendetta2 - Fan is loud? dadzilla Air Cooling 5 December 12, 2008 09:54 PM
[FS] OCZ Reaper HPC, OCZ Platinum Rev2, WINTEC Ampx Spawne32 Buy/Sell & Trade 0 November 28, 2008 12:35 PM
