Old August 4, 2009, 10:28 AM
Default Best HSF for a P2 955?
Hey guys,
I want to push my 955 as far as I can on air.
What would be my best bet?
I'm looking at the TRUE black edition right now, other choices would be Noctua and Prolimatech.
What do you guys think? It would be in a HAF 932 or ATSC 840.
Which fans (I'd prefer a push/pull) should I slap on there.
I'm sick of my lawn mower stock AMD HSF 4000 rpm fan right now....
Thx guys!
http://www.thecomputermadesimple.com | The computer world in plain English!
Old August 4, 2009, 10:47 AM
misterd's Avatar
I have a Noctua U12P on a Phenom2 955 using the fan that it came with it. I don't get to see it anymore as my father just picked it up from me today, but my experience was that it's very quiet. The TRUE 1366 that went on my sisters i7 920 was also nice, haven't used the black edition though. And as for the Prolimatech's be aware you almost have to get them imported from the US.
My fans are usually turned down using my fan controller. I've been using Yate Loons recently, but whatever is a good deal and quiet are usually my deciding factors.
| i7 920 / Noctua NH-U12P / Asus Rampage 2 Extreme / 24GB Corsair Vengeance / Asus HD5870 / Corsair 600T / Corsair HX850 / Intel 520 240GB |
| X2 5000+ BE / Passive Scythe Ninja Mini / Gigabyte MA78GM-S2H
/ 4GB G.Skill Pi / Fractal Core 3000 / Corsair CX430-M / Intel X25-M 80GB |
| i7 2700k / CM 212+ / Asus P8Z68 Pro-M / 8GB Corsair Vengeance / Antec SLK3700AMB / Seasonic M12-II 430W / Samsung 1TB |
#hardwarecanucks on irc.freenode.net
fiat justitia ruat caelum
Old August 4, 2009, 11:47 AM
sswilson's Avatar
I'm currently benching the CM Hyper 212+ on a 720be (3 cores OC'd) with the stock fan and I have to say that I'm gobsmacked by the #s I'm seeing in comparison to my 220 rad Push/Pull WC.
I'm sure it's not the absolute best air cooler out there, but the fact that it performs this well with the included stock fan, and can be purchased for slightly over $30 really has me questioning why anybody would pay more than twice that amount for a cooler without a fan. At best you might squeeze an extra 2 or 3 degrees under heavy load.
Old August 4, 2009, 12:00 PM
How loud is it?
And how sexy does it look? Yes I'm all about looks just like with girls
Old August 4, 2009, 12:23 PM
sswilson's Avatar
Originally Posted by ADay2Long View Post
How loud is it?
Here's the installation guide I did on the same motherboard as you're currently running (there's some naked HSF shots if you're looking for sexy.... :) ).
Coolermaster Hyper 212 Plus AMD Installation & Clearance
As far as how loud it is.... I'm not the person to ask. 27 years of working around aircraft has made me immune to most issues along that line, but I will say that for a stock 2K rpm fan it's not bad at all. Also, for $35 you'd be able to purchase whatever fan(s) you wanted and still come in under what a higher end cooler would cost sans fans.
edit: Here's the full review AkG did a few weeks back......
Cooler Master Hyper 212 Plus CPU Cooler Review
Old August 4, 2009, 12:58 PM
Yes I'm very shallow when it comes to heatsinks
Alright, how about the stock fan with the Hyper 212+ and the stock fan on the AMD HSF? ... sound wise I mean.
Old August 4, 2009, 01:02 PM
sswilson's Avatar
Seems quieter to me, but then again I'm running a total of 15 1350 YLs within 2 feet of each other so it's kinda hard to tell.......
edit: I also only ran the stock cooler for a total of 24 hours so I didn't have much of a chance to build up a good impression of it's sonic signature.
Old August 4, 2009, 01:06 PM
Hell, for 30$ I can give this little guy a try!
Intel i7 920 or Phenom II 955? AmuseMe CPU's and Motherboards 30 August 13, 2009 05:00 PM
Best 955 mobo? bumfloss CPU's and Motherboards 13 August 11, 2009 12:16 AM
new AM3 955 build bangers'n'mash New Builds 8 June 20, 2009 06:25 PM
955 or 940? upcoast604 CPU's and Motherboards 10 May 7, 2009 03:22 PM
NCIX has the Phenom II 945 and 955 up snoosebum CPU's and Motherboards 5 April 22, 2009 11:16 AM
