  #41 (permalink)
Old December 30, 2010, 02:37 PM
putting together a computer right now, and I have this cooler. The mobo backplate that I took out had a layer of insulation as part of it. Given that the backplate that I'm supposed to replace it with is bare metal, I assume I need some sort of insulation layer between it and the back of the motherboard?
Do I just need to tape it down with electrical tape, or do I need to do anything more sophisticated?
  #42 (permalink)
Old December 30, 2010, 02:47 PM
chrisk's Avatar
Folding Captain
The Hyper212 I had came with a layer of insulation on the 212 backplate already (the instructions on the Coolermaster site says to leave it on). Just installed it on top of the mobo plate already present.
Fold for team #54196
  #43 (permalink)
Old December 30, 2010, 02:48 PM
sswilson's Avatar
Are you installing it on an intel system or an AMD system? If it's an Intel system it installs with the "feet" facing the bottom of the motherboard like this image, and the insulation is on the "feet".......
If you're installing it on an AMD system, the plate will be installed upside down compared to the image, and you'll see that the entire plate is insulated.
  #44 (permalink)
Old December 30, 2010, 02:56 PM
chrisk's Avatar
Folding Captain
Here in this attached pic, you can see that the side you show in your picture is the side that points to the mobo for Intel:
  #45 (permalink)
Old December 30, 2010, 03:02 PM
you guys are right, I just didn't notice the difference between the bare metal and the insulation cover, cause they are a similar color. Silly error. I noticed that it said to not remove the insulation, but I mistakenly thought that was referring to the mobo, not the coolermaster backplate.
Doing an AMD install, and just got the backplate on. Don't think I'll have any more issues, but if I do I'll let you guys know :P
  #46 (permalink)
Old January 28, 2011, 09:40 PM
SugarJ's Avatar
Just a quick thank you. While I've built lots of stock AMD systems for office use, I'd never put an aftermarket HSF on one until tonight. Your guide is so much clearer than the little pictures on the install manual.
  #47 (permalink)
Old January 29, 2011, 04:43 AM
sswilson's Avatar
Glad to hear it helped.
  #48 (permalink)
Old January 29, 2011, 06:22 AM
Exlibris's Avatar
Thanks for the guide, might get one of these next time, as I've always been annoyed by have very limited clearance to the RAM slots closest to the CPU.
  #49 (permalink)
Old February 7, 2011, 07:50 PM
I have had this cooler and like it. I am now running it push pull using two GELID Silent 4 pin fans. My question is how to hook them up to run the same rpm? I have them installed now in my only 2 4 pin headers in my boars (Asus P7P55D-E pro) it has the one cpu which I think is required and the second beside it is like "case fan 2" Is there a way to get them to be the same rpm?
  #50 (permalink)
Old February 8, 2011, 03:43 AM
sswilson's Avatar
You should have settings in bios for % of fan speed, and/or you could always invest in a fan controller.
Cooler Master Hyper 212 Plus CPU Cooler Review Comment Thread AkG Air Cooling 268 April 16, 2010 03:23 PM
EQ3 Warehouse Clearance Sale *Toronto Only* Eagle Eye Off Topic 12 March 24, 2009 11:19 AM
Hyper-Threading Jake_HT CPU's and Motherboards 4 February 26, 2009 07:02 PM
Rapid's Clearance event...must go Rapid-X Buy/Sell & Trade 20 October 30, 2008 02:38 PM
