  #21 (permalink)
Old August 26, 2009, 06:43 AM
sswilson's Avatar
What kind of Vcore are you using to get 4.3G? That's definately the kind of OC that would push an air cooling solution.
ASUS SaberTooth 990FX / AMD 1090T / 2X4 Gig Gskill RJ X / XFX Pro 1000W PSU / 2X MSI 560GTX-Ti Twin Frozr II / Corsair F120 / WD 6401AALS
TT Lvl 10 GT / DDCPX-Pro / EK XT 240 Rad / 2X Scythe Ultra Kaze / EK Supreme HF / XSPC 250mm Res / Dell Ultrasharp 2209WA
Asus CH IV / Athlon II X2 250 / 4X2 Gig GSkill Pi PC3-12800 / 2X GTS 450 / PC P&C 750W Silencer / PA 120.2 /
MCR220-QP-Res / Swiftech MCP350 Pump / XSPC Laing DDC top / EK-Supreme HF / Lian-Li Pitstop T60 / Samsung 931BF
  #22 (permalink)
Old August 26, 2009, 07:27 AM
bojangles's Avatar
Nice pics sswilson! Flash is not your friend, but exposure is! Too bad on the light conditions, but hey, you have what's available. Excellent procedure and I'm actually considering getting a small AMD rig for a performance HTPC. I just may look into this cooler. Thanks man!
  #23 (permalink)
Old September 5, 2009, 11:42 AM
Supergrover's Avatar
Well I broke down and picked one up for the HTPC.
I havnt had a aftermarket HS in years now, the HTPC is using the POS stock hs and my rig is under water.
Even though it isnt designed for passive I am interested if it will keep my 8750 cool enough without the fan.
Since the 8800gt that is in the HTPC is passive it would be nice to have a passive solution, if not then no big deal.
I will post up the results in this thread when I do but keep in mind the 8750 isn't overclocked and it isn't a huge heatdump to begin with.
212 should be here Monday.
R.I.P.
  #24 (permalink)
Old December 11, 2009, 10:30 PM
DkRk's Avatar
Gotta bump this, and just say 'thank you!' for this awesome guide. It helped me get through the heatsink installation very easily. Hope you crank out more of these!
Protect your chicken from Dokken.
  #25 (permalink)
Old December 14, 2009, 05:55 AM
sswilson's Avatar
Glad to hear it helped out. Installing your first aftermarket cooler can be a daunting task and I know I appreciated pictoral guides when I was first starting (hell I still appreciate them if I'm having problems... ;) ).
Once you've got everything together, be sure to post some pics.
  #26 (permalink)
Old February 17, 2010, 10:56 AM
definately think i did this installation wrong. your mounting nut on the back and on the processor side seem to be flush with the board. mine arent flush. The heatsink doesnt move though so i'm afraid of overtightening it.... question did you just a wrench to hold the nut in place while u tightened it down...otherwise it just spins at a certain point.
  #27 (permalink)
Old February 17, 2010, 02:02 PM
sswilson's Avatar
There should be a nutdriver with the hardware you got.
Can you get us a pic of your install?
  #28 (permalink)
Old February 17, 2010, 02:14 PM
Yah i'm going to yank it back out and try to get some pictures up. I used the nut driver but eventually it stops...and it still wobbles back and forth until i use the screw from the bracket to tighten it down. Its probably fine but never done a heatsink swap so i'm a little freaked out haha.
  #29 (permalink)
Old February 17, 2010, 02:15 PM
also did you do the "line" method with the thermal compound or did you spread it urself. I did the spred it very thin....thin enough so that you still see "amd" clearly. If i end up taking the heatsink off better make sure im doing that right as well.
  #30 (permalink)
Old February 17, 2010, 08:17 PM
Ok i decided to boot the computer for the first time rather than yank it again. Right now in msi bios it's reading 45 degrees Celsius CPU temp. I'm letting it sit in the bios screen. Is this high?
Cooler Master Hyper 212 Plus CPU Cooler Review Comment Thread AkG Air Cooling 268 April 16, 2010 04:23 PM
EQ3 Warehouse Clearance Sale *Toronto Only* Eagle Eye Off Topic 12 March 24, 2009 12:19 PM
Hyper-Threading Jake_HT CPU's and Motherboards 4 February 26, 2009 08:02 PM
Rapid's Clearance event...must go Rapid-X Buy/Sell & Trade 20 October 30, 2008 03:38 PM
