Old August 2, 2009, 09:58 AM
JD JD is offline
Default Best fan for HDT-D1284
Curious as to what your guy's thoughts are on the best fan for this: XIGMATEK
Though it can't be super loud, say under 30dBA? PWM would be nice but I can't seem to find anything that has a good range of RPMs.
Also probably going to get the backplate mount too, since I doubt those push-pins are really doing a good job.
Old August 2, 2009, 08:47 PM
JD JD is offline
lol basically all the ones I looked at. None of them jumped out at me though...
The stock fan is already 1500RPM PWM rated at 56CFM.
S-FLEX "F" and Gelid Wing 12 are probably my main choices since I run them in my PC so I know they're decent.
That PWM Delta NCIX has is nice too, that thing should keep everything cool with 113CFM at a silent 46dBA
Old August 7, 2009, 04:47 PM
JD JD is offline
Of these choices, which one would you guys say would work the best on the D1284? It's a down-draft cooler, not the tower style.
Arctic Cooling Arctic F12 Pro PWM 120MM Fan 400-1500RPM 57CFM FDB (Picture here)
NMB-MAT 120MMX25MM Low Speed Fan 1600RPM 63.57CFM 27DB
GELID Solutions GELID Wing 12 1500RPM 120MM UV Green Gamer Fan 64.3CFM 25DBA NFB
Scythe S-FLEX SFF21F 120MM Cooling Fan 1600RPM 28.0DBA 63.7CFM FDB
And those are ranked by price from lowest to highest (after PM'ing of course).
Last 3 seem nearly identical spec wise, other than each having their own blade design. PWM on the Arctic Cooling is a bonus, but it's a bit lacking in CFM. And well I doubt an OC'd E6600 will really need varying fan speed.
Old August 7, 2009, 05:17 PM
I actually used those ACs.. I got to say, they were bloody silent and pushed a descent amount of air, statistics.. sorry jdrom can't remember, stopped using them few months back.. Only problem with that is the design, not like a regular fan, you would usually use it as an exhaust, if you're fan is mounted inside a front panel, forget about instake.. the outside are sticks out.. but I loved them...
I've heard good things about the Gelid, as for Scythe.. the reps they've built in the market, probably has an edge.. Though I would like someone to try the Gelid really.. pushes more air than the scythe with little less noise.. interesting..
Old August 7, 2009, 06:47 PM
Sushi Warrior's Avatar
I would get the Wing 12's, they come with a speed controller and rubber mounts and such and use great bearing tech (same as NoiseBlocker fans) and can be PM'd to $12 I believe.
Old August 7, 2009, 08:21 PM
JD JD is offline
Yup, AC stuff is typically good quality for cheap. Can't go wrong with them IMO.
To be honest, having both the Gelid Wing 12 UV Blue and Scythe S-FLEX F in my own PC, the S-FLEX is a better fan. Quieter at 12V IMO, and when ran at 80% (1360RPM), it's very quiet. To make my GELID similar, I need to run it at 70% (still roughly 1360RPM). At 12V, I'm pretty sure the GELID was more like 1600RPM than 1500RPM. Though I bought the GELID of the bling of the UV Blue blades, not for performance.
Yeah, about the same price as the S-FLEX F.
Even though it's not for me, it's just hard deciding which to go with.
Old August 7, 2009, 08:28 PM
Guess it all comes down to price, I think the speed controller and the conveniences of the nano-flux bearing (but no flux capacitator!) and the bonus rubber mounts would put it above the Sflex-E if they both perform the same really. Do you need a speed controller? If not then I guess the Sflex-F would be the way to go.
Old August 8, 2009, 09:33 AM
JD JD is offline
Yeah for the price, the GELID comes with way more accessories, but being on a CPU heatsink, none of those get used.
HDT-S1283 lazypanda Troubleshooting 4 July 30, 2009 11:11 PM
Xiggi HDT-s1283. What fan to throw on it? And check this out. chouchou Air Cooling 5 July 9, 2009 08:40 PM
HDT RS1283 Vs TRUE 120 arekieh Air Cooling 3 November 9, 2008 03:09 PM
Big Typhoon VX & Xigmatek HDT-D1284 Hardware Canucks Reviews & Articles from the Web 0 April 24, 2008 05:20 PM
Xigmatek HDT-S1283 CasheKicker Water Cooling 0 February 19, 2008 01:26 PM
