Old July 31, 2009, 10:05 PM
Default These Temps OK?
Been a while since i overclocked anything. This was pretty easy to do..
I am using an Xigmatek HDT-S1283 with a bolt kit and AC MX-2 paste (Pretty sure i put tiny bit to much on)
The temps seem a little high from what i have read all over (google). Keeping in mind its one of the hottest weeks ever here in Victoria B.C. Just wanted to get some opinions.
Thanks
Old July 31, 2009, 10:26 PM
Eagle Eye's Avatar
That E8400 should easily do 4.0GHz, your temps are fine just keep things at or below 60oC. Also update CPU-Z to 1.52.
EE
Old August 1, 2009, 05:02 AM
gingerbee's Avatar
sorry but why does everyone say 60c or below i mean i have not had a chip under 60c at full load in oh like 7 or more years. the e8400 has a max ihs of 72.4 which is not the core max.
Old August 1, 2009, 05:13 AM
Prof. Dr. Silver's Avatar
Under full load that is a perfectly normal temperature... 60C is the temperature a lot of people are comfortable with... which means you've got quite a few degrees left to play with! :)
Hardcore Folding at it's BEST! HWC - TPU.... There can be only one team in front! TPU, can you smell our *sses already?
Old August 1, 2009, 06:30 AM
Thanks guys. I have seen more then a few people claim under 40C at load so i was a little worried. I might go to 4GHz but its not really necessary so i might keep it like this and try to enable EIST.
Old August 1, 2009, 11:43 PM
burebista's Avatar
Keep distance to TJMax >20 and happy OC-ing.
Peoples are too worried by temps nowadays.
Old August 2, 2009, 04:11 AM
gingerbee's Avatar
i second that. i think it's been too long since the pentium stove top cooker ha ha
i7 temps gingerbee Overclocking, Tweaking and Benchmarking 1 March 9, 2009 09:02 AM
Are these temps right? overlords Air Cooling 15 January 18, 2009 03:10 PM
CPU temps vs Core temps sloth CPU's and Motherboards 13 October 19, 2008 12:34 PM
e4500 temps djnocide CPU's and Motherboards 0 April 11, 2008 03:28 PM
temps Kassela Troubleshooting 7 March 13, 2008 02:46 PM
