  #21 (permalink)
Old July 28, 2009, 10:07 PM
Originally Posted by chouchou View Post
5. Ambient temp of about 27 degrees.. Yes it's stupid hot.
6. Running a HAF 932 custom side panel mod... 3x 120mm, 1x 240mm intakes, 3x exhausts
Last updated: July 28/09
Christ 27C room temp that's hot - You must have really piss poor insulation - Today it's 36-37C outside it's bloody hot and inside windows closed even without AC and it's 22-23C.
  #22 (permalink)
Old July 28, 2009, 10:33 PM
chouchou's Avatar
yeah, its brutal. i live with my window facing the sun at peak hours, aka i go school at 7 come home at 12 to an insanely hot room...
i have a fan that i plan on leaving on 24/7 now LOL.. maybe time to invest in a portable a/c?
HAF932
Q6700stock || SLI GTX 260 c216 =) || 2x2gbMushkinRedline PC2-8000
750i FTW || WD 36GB Raptor || WD 640GB Caviar Black || HX620W
  #23 (permalink)
Old July 29, 2009, 05:15 AM
jcmaz's Avatar
when do u even need AC in Vancouver besides these 2 weeks??? Might as well spend that money on moar computer parts :)
-Plato
  #24 (permalink)
Old July 31, 2009, 03:28 PM
lowfat's Avatar
1. CPU (Chip and OC?) - i7 920 @ 4.2GHz
2. CPU Cooler - Modded CM V10 w/ 125W TEC
3. Thermal Paste - IC Diamond
4. Idle Temperatures / Load Temperatures across all cores -
IDLE: ~65C
LOAD: ~45C
5. Ambient Temperature - 20C
6. Case fans - stock. 2 x 180mm intakes, 1 120mm exhaust.
Mael
Big Lian Li
Forever Alone
  #25 (permalink)
Old August 18, 2009, 03:10 AM
Trial Member
1. Idle Temp - Core 1&2: 35-37 degc, Hottest core: 39 degc, Coolest core: 33 degc
2.
Load Temp - < 39-48 degc from web surfing + virus scans
3.CPU: Q9550 (EO), stock speed with Dynamic Energy Saver enabled from gigabyte EP45-UD3L
4. CPU Cooler - Thermalright TRUE Black push/pull (non-lapped), Push Fans: CM silent 120mm LED at 2000rpm 90CFM, Pull fans: 120mm LED fans at ~ 1500rpm,50+CFM to exhaust fan
5. Thermal Paste - Thermalright CHILL Factor 2, Parrellel Bars on heatsink (1/3 lengths all sides), one tiny drop at centre of CPU
6. Ambient Temperature - 25 degc
7. Case fans - Intake: 2 x 120mm front mesh filter LED fans 1600-2000 rpm, Exhaust: 1 x 92mm 2800rpm (accelerated to 3200+rpm by cooler fans as shown), PS: Vantec ION2 135mm silent low speed fan, side fan removed.
8. Pressure Setup - Slight Positive
9. Case : iCute ZL11-4GA-BB (side window w/ CPU + GPU ventilation holes)
  #26 (permalink)
Old August 18, 2009, 06:46 AM
1. CPU (Chip and OC?) - QX9650 @ 4.0GHz @1.38V
2. CPU Cooler - OCZ Vendetta 2 with stock fan
3. Thermal Paste - AS5 applied on the centre rails of the cooler
IDLE: ~29*C
LOAD: 59-65*C
5. Ambient Temperature - 24*C
6. Case fans - 2 Scythe S-Flex "F" 120mm fans, 1 of which intakes and the other exhausts
  #27 (permalink)
Old August 19, 2009, 07:15 PM
Dwayne's Avatar
1. CPU (Chip and OC?) - E8400 @ 3.6 GHz
2. CPU Cooler - OCZ Vendetta 2 Stock fan Pull
3. Thermal Paste - MX-2 / 2 thin lines
4. Idle Temperatures / Load Temperatures across all cores - Idle 44/35 Load 57/51
5. Ambient Temperature - about 21
6. Case fans - Antec 900 - Front fans settings mid, Top exhaust fan setting mid, rear exhaust fan mid, 120mm side fan Scythe Slip Stream intake (500 rpm)
Screen shot after about 80 min of small ffts.
Dwayne's Rig - Asus Prime Z370-A : i7 8700k : Corsair Vengeance 32 GB DDR4-3000 : Corsair RM650x PSU : Corsair H100i V2: Fractal Design Meshify C : EVGA GTX 1080 :
HTPC - GigaByte H67MA-UD2H : i3 2100 : 8 GB Mushkin Silverline Stiletto : Antec TruPower 550W : : Corsair H100 : Sapphire HD 6670 : Corsair 650D: Kingston 60 GB SSD Boot
Tablet - Samsung Tab A 10.1"
Wife's Rig - MSI GL72M 7RDX
  #28 (permalink)
Old August 19, 2009, 07:28 PM
1. CPU (Chip and OC) - Q6600 (G0 stepping) @ 3.4GHz @1.33V (1.275 vid)
2. CPU Cooler - Zalman CNPS9700
3. Thermal Paste - AS5 (bead method)
4. Idle Temperatures / Load Temperatures-
IDLE: ~26*C
LOAD: 59-62*C
5. Ambient Temperature - 21*C
6. Case fans - 1 120mm fan, 2 80mm fans (standard w/ case)
System Spec Peripherals: NZXT Kraken X42 CPU cooler | Zalman MFC3 fan controller | Steelseries Apex M800 kb | Steelseries Sensei mouse | Logitech Z-2300 2.1 speakersDrobo FS 6.5TB Synology DS1515+ 15TB
Laptops: Asus G74SX-DH71 | Asus G752VY
Surface Pro 4 Core i7/256GB
Q9550 Temperatures lKashl Troubleshooting 6 July 9, 2009 11:32 AM
What temperatures are your HDD? Silvgearx Storage 10 January 31, 2009 04:33 PM
How to measure temperatures? kav Overclocking, Tweaking and Benchmarking 4 November 19, 2008 07:17 PM
Accurate CPU temperatures? Below_Cost Overclocking, Tweaking and Benchmarking 8 February 6, 2008 03:17 PM
