Old July 25, 2009, 01:26 AM
MittWaffle's Avatar
Default Scythe Mugen 2 - Temps high?
Scythe Mugen 2 installed with the cooler facing up alternatively than back.
Like this.
Air Flow
[F A N]
I have a concern, im running my I7 @ 3.8 1.25v and real temp is showing me 47 - 45 degrees idle (this is on standard fan control settings.)
I have the back bracket on as snug as possible, thermal paste was spread lightly with a credit card (couldn't see cpu surface fully covered in paste but didnt seem over the top.)
Temp Readings on Turbo Fan settings.
46,44,48,46
Load is mid to high 70's
I have a cool master HAF 932 case, so airflow isnt the issue. I need some help with what might of gone wrong. The cpu socket clip was snugged up properly to the back plate, and the cooler was screwed correctly.
Any help is appreciated to find out where I can back step to fix the problem.
Old July 25, 2009, 02:42 AM
burebista's Avatar
But what's the problem?
You have an i7 @3.8Ghz and 7x°C in load. For me it looks OK.
What's your room temperature? HT on?
Old July 25, 2009, 03:38 AM
MittWaffle's Avatar
HT is on, room temp..roughly 20-25 right now.
Reason being that I ask is my concern with my idle temps, load could always be a little lower though.
[FS] Q6600 w/ Scythe Mugen, eVGA 750i FTW, 2GB Corsair, G15, G25 wonton1017 Buy/Sell & Trade 14 July 17, 2009 01:48 AM
Water Temps seem...high. Sagath Troubleshooting 4 April 6, 2009 06:27 PM
Temps seem a little high... element291 Air Cooling 28 January 15, 2009 08:33 PM
4870 Temps too High? arekieh Video Cards 10 November 28, 2008 07:41 PM
High Temps BALISTX Overclocking, Tweaking and Benchmarking 20 July 14, 2008 04:32 PM
