Old July 23, 2009, 09:42 PM
chouchou's Avatar
Default Fans mounted on radgrill making wierd noise?
I suspect it's from the intake air going through the radgrill --> through the fan into the case.
Is there any way to space the fan from the fangrill?
Old July 23, 2009, 10:01 PM
tape.
foam.
washers.
Old July 23, 2009, 10:15 PM
MpG's Avatar
MpG MpG is offline
Got a cheap fan you never use? Punch out the motor and blades, and use that as a shroud to give the fan blades a little clearance.
Old July 23, 2009, 10:26 PM
chouchou's Avatar
cool, sounds good. will give these a shot
thanks!
gtx 275 is making noise... (not the fan) lexmark1 Video Cards 19 May 20, 2009 04:22 AM
Auzentech X-fi prelude making noise elec999 Audio 1 February 1, 2009 09:09 PM
Samsung Spinpoint F1 1TB Making Lots of Noise arekieh Troubleshooting 3 November 27, 2008 08:16 PM
Computer mounted on Corkboard? Infiniti Off Topic 7 August 30, 2008 03:17 AM
Cosmos watercooling question - top-mounted rad... Synth Water Cooling 8 July 19, 2008 12:03 PM
