Old July 22, 2009, 09:55 PM
bkh2's Avatar
Default Questionable Thermalright Ultra 120 Extreme Results
I bought a Thermalright Ultra 120 Extreme 1366 cooler in hopes that I would get good temps so I could attempt an overclock with my i7 920.
At idle, temps are ~40 degrees C
At Load, stock speed: ~low 70's degrees C
I've tried overclocking to 2.9 Ghz (i7 940 speed) on stock voltage using TurboV (just to observe any increase in temps). I noticed an increase by ~1-2 degrees C.
Regardless, 70 degrees C isn't exactly good at stock speeds, is it? Especially with an aftermarket heat sink. Although, my ambient is ~ 27 degrees C.
Any feedback would be awesome.
Old July 22, 2009, 10:58 PM
aviduser's Avatar
What were your results with your previous heatsink?
I think seeing that the max temp for i7's is 100C, your doing fine. I'm sure you know they're not very easy to keep cool.
I5 4670K 4.4ghz - Gtx 780 Amp - 2x4 Corsair Vengeance - MSI z87-g43 - Tx 850w - Asus pbq278q
Old July 23, 2009, 05:41 AM
SKYMTL's Avatar
HardwareCanuck Review Editor
Which fan are you using on that TRUE?
Old July 23, 2009, 05:47 AM
bojangles's Avatar
A push-pull setup will really help you on temps. You may have a "HOT" chip from a certain batch like mine and 3oh6's.
Old July 23, 2009, 06:59 AM
burebista's Avatar
AFAIK TRUE without lapping and washer mod is just an average heatsink.
Old July 23, 2009, 08:13 AM
misterlarry's Avatar
Just wondering, for all us non-i7 types, what are the normal temps on a stock i7 with stock cooling?
I'm very happy with the cooler I'm running on my rig. I've never lapped or modded the cooler.
Asus Z97-A - Intel i7 4790K @ 4.0 GHz - Corsair H80 CPU Cooler- 4x8 GB G.Skill Ares DDR3 2400 - EVGA GTX960 4GB
1x240 GB Mushkin Chronos Enhanced SSD - 1x500 GB Seagate Hybrid Momentus - 1X2 TB Western Digital Green - Pioneer DVR-212D - Antec P182 - Rosewill Photon 850 - 2X24" Acer G246HYL - Windows 7 Pro 64 SP1
The world is your oyster. Shuck away my friend, shuck away!
Old July 23, 2009, 09:14 AM
somecanadianguy's Avatar
I'm using a TRUE with only the one fan that came with it (cause I'm broke and can't afford more/better fans).
Folding @ 3.486GHz temps barely hit 60c.
When I run 3.8GHz temps top around 72c.
This is with an ambient room temp of 23 - 26c.
I'd say that either your chip is a REALLY hot one, or there may be a problem with your mount job...
What kind of TIM did you use, and how much?
I've heard many people say to lap the TRUE, but I didn't bother since my temps looked fine to me.
Perhaps you could try that if all else fails...
Old July 23, 2009, 09:30 AM
burebista's Avatar
TRUE base
Old July 23, 2009, 09:36 AM
JD JD is offline
Another point, what kind of case airflow do you have? A picture would help greatly.
And 27C ambient is high IMO, so you can't expect low temperatures when the air going into the heatsink is already that warm.
Old July 23, 2009, 09:41 AM
So far the lesson I've learnt is "don't lap the TRUE".. the little bow they have actually helps in mounting, I know couple people who lapped their heatsink, had issues with temp issues, some also had issues that the heatsinks wasn't tight enough, it would literally move from the mounting bracket (well not really move, I hope you get my point)..
At least that's what i've come across..
Thermalright Ultra 120 Extreme orientation? Bones Air Cooling 23 April 25, 2009 06:56 PM
Thermalright Ultra 120 Extreme Mulder Air Cooling 5 September 30, 2008 12:37 AM
FS: Thermalright Ultra 120 Extreme JD Buy/Sell & Trade 5 July 14, 2008 03:49 PM
WTB Thermalright Ultra 120 Extreme rom0n Buy/Sell & Trade 18 June 1, 2008 01:43 PM
A second look at the Thermalright Ultra 120 eXtreme Babrbarossa Reviews & Articles from the Web 2 May 4, 2007 06:23 PM
