Old July 18, 2009, 03:03 PM
Lima's Avatar
Default Sharing fans between 2 machines.
Hello peoples,
I am wondering how to go about setting up two particular case fans.
I have a mountain Mods Ascension case and I am gonna have two machines running out of it. The Ascension has two fans on the top panel and I want those fans to run even if just one of the machine is on.
I don't know if plugging them into both boards is safe and I don't know very much about electronics to build a component or know which one I'd need to do this.
You guys with the know how, please let me know what I can do.
Old July 18, 2009, 03:09 PM
MpG's Avatar
MpG MpG is offline
Don't plug a single fan into two boards. Otherwise, you'll wind up sending current through the non-active system, which has the potential to cause all kinds of problems.
I'd say that you might want to consider just hooking both fans up to the system that's hotter. Unless there's some purpose-built piece of hardware that will handle things for you, you're looking at a bit of wiring to make a relay setup that will handle things properly.
Old July 18, 2009, 04:31 PM
Lima's Avatar
Using the fans on the system that produces the most heat is a great point. Since I can try different configurations as well, I might as well run them by you guys as well.
Three rads total. Two in main system and one in second.
1-Two rads are going to fill the case with more hot air so I should put those fans on with the main rig expelling air out the top while the rads push air in.
2-I can also put one rad in front pushing air in and the second rad pulling air out. Then, give the two fans to the second machine to expel air out the top as the rad pushes air in the front.
3-Any others ?
What do you guys think?
Old July 18, 2009, 04:36 PM
MpG's Avatar
MpG MpG is offline
I'd probably look at configuration#1, although a few more exhaust fans elsewhere would obviously help balance things out. Option #2 will see the second rad getting the first rad's exhaust air, which will hurt its performance. As a rule of thumb, you want the radiators to be getting the coldest air possible, and then do your best to balance those rads out with exhaust fans.
Old July 18, 2009, 05:00 PM
Lima's Avatar
Each system is going to get a 120 mm in the drive bays. Not sure where else to put some, no more holes.
A trinity front would hit the spot right about now. but if ever, it gonna have to wait for now :(
Old July 18, 2009, 05:53 PM
Lima's Avatar
I could also set all the rads to expel the air outwards and all the other fans to intake air.
What do you think of that one?
Old July 18, 2009, 06:23 PM
Lima's Avatar
Hey!! What about a switch that will let me shift the power source of the fans? So I can control which system powers the fans.
example: Fan to splitter > splitter to switch > one three pin connector to each motherboard. Like that, when I have the power off on the main system I can just divert power from the second machine and prevent power crossing over to the other system at the same time.
Now to find out what a switch like that would be called/or exist and where to get one.
Anyone?
Old July 18, 2009, 06:32 PM
3 of 7's Avatar
It would be pretty simple to use 120v fans and 2 relays. Just hook up one relay to each power supply to trigger the hot on the 120v line. If both psu's are on it won't matter because both relays would be supplying 120v from the same line.
Nature always sides with the hidden flaw
Old July 18, 2009, 06:33 PM
3 of 7's Avatar
I just thought of another way, the relays could turn on a 3rd psu to power the fans as well. That way you could use cheap automotive relays too.
Old July 18, 2009, 06:49 PM
3 of 7's Avatar
Here's how I would do it with the 3rd psu using 2 cheap Bosch automotive relays. You could even steal them out of a wreck ( look under the hood, they all have relays of one kind or another )
[FS] New Zalman fans, used Scythe and blue LED fans mhw100 Buy/Sell & Trade 15 June 22, 2009 02:32 PM
Outlook from multiple machines RainMaker O/S's, Drivers & General Software 4 April 20, 2009 05:23 PM
Sharing Resources Mysteryous Networking 2 September 22, 2007 12:06 PM
Two folding machines Amon HardwareCanucks F@H Team 16 September 14, 2007 04:05 AM
Sharing files and folders mcgirkz Troubleshooting 0 September 13, 2007 12:22 AM
