Old July 17, 2009, 10:04 PM
Default Has anyone ever tried routing their pc's heat?
Like so:
Re: [FAH] Shutting down ... - dslreports.com
I got the idea from my portable AC:
http://i300.photobucket.com/albums/n...d/DSCF2873.jpg
Notice how the heat from the AC is sent out through the giant tube. My window has a plate with a hole for it install. What if I hooked up all my back120mm fans to large tubing like that (I'd need a second plate)? That would have the heat transferred outside rather than my room. But the huge fan on top of my Antec 1200 case would need be problematic, but that's beside the point.
Anyone done this?
Old July 21, 2009, 06:38 PM
mattydies's Avatar
I have not done this. I am however interested in the concept, as well as making internal duct work (fresh air to my cpu cooler, and strait out the case, same for the GPU, and a small tube over the ram to pull normal case air past the ram, and then out the case). I plan to buy my new main board before doing the work, and redoing it again.
I am only speculating (and running some mild heating/ventilation experience in other applications) If you want to do this I would suggest using a high flow fan to maximize the effort. Even then perhaps 2-3c difference? Just a guess. How much of a difference is there between your case air temp and ambient air temp?
Old July 21, 2009, 07:39 PM
b1lk1's Avatar
Alot of work for minimal/no gains in heat removal. You'd be lucky to not cause the stuff to run hotter. Invest in a window box fan instead.
DAILY: MSI 970 Gaming/FX6300/16GB Corsair DDR3/ASUS CU II R9 270 2GB/128GB SSD+750GB HDD+2TB HDD
Has anyone ever tried routing their pc's heat? Z Overlord Cases 8 August 23, 2009 09:03 PM
Has anyone ever tried routing their pc's heat? Z Overlord Water Cooling 14 July 18, 2009 02:42 PM
Heat plate Bucklaz Off Topic 4 May 26, 2009 07:15 AM
Water Cooling Routing help - Two GPU and Chipset futures Water Cooling 6 May 20, 2009 02:19 PM
quick question regarding loop routing donimo Water Cooling 11 February 14, 2009 11:36 AM
