Old July 12, 2009, 07:17 AM
Default What's the "protective label" for on HDT-S1283 ?
Hi,
Here's my story : I recently bought a Xigmatek HDT-S1283 to replace the stock Intel cooler. For those who don't know, there's a "protective label" that you have to peel off from the base of the heatsink before installing it. The problem is, when I removed it, most of the adhesive stayed on the base .
I don't know who's fault is (but it's not mine), but that is certainly something I wasn't waiting for. I had to take some solvent (in this case, lighter fluid) to remove all the sticky adhesive from the base, and it was definetely a bit messy, plus it took some time...
Anyone had the same problem ?
Except from this, I'm relatively happy with the cooler: not too big, fits nicely in my case (Sonata III) and on my board, quiet, and 20 °C cooler than the stock one on load.
E8400 (C0) @ 3.75 GHz -- HDT-S1283
Old July 12, 2009, 07:38 AM
AkG's Avatar
AkG AkG is offline
Hardware Canucks Reviewer
Yeah I HATE when they Mfg'ers that too! The easiest way is with rubbing alcohol and a lint free cloth, just make sure to work WITH the direction of the heatpipes or those metal posts can shred the cloth and leave bits stuck between them and the heatpipes. Usually comes off fairly quick but it is a real pain in the arse.
Old July 12, 2009, 07:58 AM
Lint free cloth... yeah, right...
I didn't know rubbing alcohol was working on adhesive. I do know lighter fluid works fairly well, I'm just not sure if it's damageable/non-optimal.
Old July 12, 2009, 08:02 AM
sswilson's Avatar
Lighter fluid is going to leave a bit of a film, as would nail polish remover (probably the best publicly available chemical solvent). If you're using either of those, ensure that you use a high % isopropyl alcohol to clean it afterwards.
Old July 12, 2009, 08:30 AM
AkG's Avatar
AkG AkG is offline
All I can say is 99% worked well on both the OCZ Vendetta 2 and Xigmatek S1283, and bunch of others I've reviewed. The crap came right off with a bit of work.
Though if I run into big issues with glue I use an orange based cleaner (actually called Icky Sticky Unstuck...IIRC) and then a good cleaning with 99%.
YMMV ;)
Old July 12, 2009, 08:48 AM
gingerbee's Avatar
common happening and i thought 99.9% rubbing alcohol was a given.
Old July 12, 2009, 08:52 AM
Perineum's Avatar
Originally Posted by foxman View Post
Hi,
Each and every one of these things I have bought has done this. It's a severe piss off. I've done it 15 times or so now and I've tried various ways of doing it without success.
You're definately not alone.
Old July 12, 2009, 08:59 AM
gingerbee's Avatar
it's not you guys the mfg's have to switch to a low tack adhesive.( paper towel and 99.9% is the best you can do till they start playing ball. have sent several emails cause i to have gone through this to many times to count. this month was slow maybe 10)
Old July 12, 2009, 09:09 AM
geokilla's Avatar
You just reminded me to go get coffee filters =)
The two times that I peeled the protective label off, I didn't notice any adhesive stuck on the cooler. Maybe I should take my cooler off and re-apply some AS5 if there is some adhesive stuck on it.
Old July 12, 2009, 09:23 AM
JD JD is offline
YMMV ;)
The one I see around here is called Goo Gone. Works well on removing sticky residue but I haven't used it on heatsinks.
Xiggi HDT-s1283. What fan to throw on it? And check this out. chouchou Air Cooling 5 July 9, 2009 08:40 PM
Xigamek HDT S1283 better than TRUE black? wonton1017 Air Cooling 7 July 9, 2009 07:20 PM
Xigmatec HDT-S1283 review. stoanee Member Reviews 2 March 17, 2009 06:37 PM
Xigmatek HDT-S1283 CasheKicker Water Cooling 0 February 19, 2008 01:26 PM
