Originally Posted by burebista I search my pockets and I find my last 2 cents.
Nope SKY, their main problem is base finishing an poor contact on 2 heatpipes with IHS (at least for non-Nehalems/Phenoms CPU's).
Fortunately Hyper 212 seems to have a better base and a 2k fan on it. Both helps it to climb the charts but I highly doubt that who buy it can stand a 2k fan daily and he'll keep a Nehalem @3.8GHz and 1.45V at 65.5°C in a case at 23-25°C ambient. |
Sorry, I lumped in the Hyper and one other new HDT cooler I have seen (unreleased) in with the current crop. Bases have improved a lot over the first generation of HDTs so to me they are a non-issue these days...unless you are buying a Vendetta 2 or Xigmatek S1283.
Until then those charts are just some numbers without an anchor in real life.
The main issue is control. What happens if ambients one day are 20C and the next time we test a cooler are 26C? Here in Canada and even in your native Romania, massive temperature swings happen on a regular basis. That is reality. Unfortunately, we can't control that and we all know how much ambient temps can influence results. So much so that comparing a cooler in a 20C room and again in a 24C room would result in an exponential difference in CPU temps.
The same thing goes for putting a cooler in a closed case environment. Since that even at idle the temperatures produced by the GPU, VRMs, memory, PWM, HDD etc, etc never progress in a linear or repeatable fashion, comparing one heatsink to another in a closed case is next to impossible.
Two more questions (at least I hope): HT was on? I ask because without HT you can gain ~10°C. Turbo ON? I ask because funny things happens with multiplier on some X58 boards when approaching to TDP limit.
That is a good observation. Turbo mode does cause the CPU to throttle when reaching its TDP limits. To my knowledge, AkG's overclocks are purely based off of actual speed without turbo mode enabled. In addition, HT was enabled as this is the setting most people use on their i7 setups.
