  #261 (permalink)
Old March 25, 2010, 08:41 AM
Patramix's Avatar
Originally Posted by ryman546 View Post
I found the 3 line thermal paste to be the most effective. Heres my temps for this cooler.
at work so havent had time to read all 15+ pages, is the 3 line TIM application the prefered technique with this heatsink.
All of life is forged from Hell, Yet from its beauty our legacy began.
My Boinc Stats
  #262 (permalink)
Old March 25, 2010, 09:34 AM
Soultribunal's Avatar
A lot of times yes with HDT Coolers. You can experiment with them and you'll find that the single dot doesn't always cover the Pipes properly in their contact. Make sure you use very small amounts though as you don't want globs of overlap on the cooler surface or TIM leaking out the sides.
ST
www.realhardwarereviews.com
  #263 (permalink)
Old March 25, 2010, 10:05 AM
Patramix's Avatar
ST
k ill give it a try, i have some experience with HDT, currently have a S1389 in my system, just never really tried the 3 lines with it.
My Boinc Stats
  #264 (permalink)
Old March 28, 2010, 04:42 PM
mchutch's Avatar
Just got this cooler with my new setup, since all the parts came the same day, installing was very easy lol.
So far it's super cool, but I'm just getting to OCing as I know the system is rock solid and I found the top OC of my 5870, on air anyways...
  #265 (permalink)
Old April 13, 2010, 04:19 PM
CoolHandL's Avatar
I love my Hyper 212+, easy to install (if this isnt your first heatsink install) temps are way below that of the stock cooler, and now i can enjoy quiet cooling with a 120mm Noctua attached in a push position. (dont need the extra noise of a pull fan)
  #266 (permalink)
Old April 16, 2010, 10:31 AM
so... is it 3 lines on the copper or on the nickel?
  #267 (permalink)
Old April 16, 2010, 11:12 AM
Patramix's Avatar
i followed a few guide on HDT past job
and everyone ive seen put it on the nickel part, not on the actual pipe, but everyone will full up the "cracks" between the nickel and cooper pipes first,
ive been pondering lapping mine but not sure if i want to try that, never lapped a HS before
My Boinc Stats
  #268 (permalink)
Old April 16, 2010, 01:07 PM
try smaller grit than what you might try first, just in case. using bigger grit, some get carried away
  #269 (permalink)
Old April 16, 2010, 03:23 PM
TopDogZero's Avatar
I second dangtx said, you really want to be careful when lapping a HDT cooler because the heatpipes are already sanded down to make them flat, it is hard to tell how much material is left and lapping too much will destroy them.
Cooler Master V10 CPU Cooler Review Comment Thread AkG Air Cooling 60 October 22, 2011 01:52 AM
Cooler Master V8 CPU Cooler Review Comment Thread AkG Air Cooling 37 June 15, 2009 10:37 PM
Cooler Master Hyper N520 CPU Cooler Review Comment Thread AkG Air Cooling 3 June 8, 2009 07:54 PM
