  #251 (permalink)
Old March 1, 2010, 09:04 AM
Originally Posted by ryman546 View Post
ok i got it to idle at 29 degrees celcius and 48 degrees celcius at max load. I had removed and reapplied in a grain of rice method. Does this sound right for a amd 965 125w?
I'm running those exact temps with my AMD 955 running at 3.7GHz per core at stock voltage but with a Corsair H50. Are you running the CM Hyper 212+ with 2 fans? Seems pretty solid, now start overclocking!
  #252 (permalink)
Old March 1, 2010, 09:05 AM
gingerbee's Avatar
ya those temps seem fine
  #253 (permalink)
Old March 1, 2010, 10:27 AM
Soultribunal's Avatar
Originally Posted by gingerbee View Post
ya see 66 cfm is to low for me for a rad fan any other suggestions that are 20$ plus dollars?.
Gingerbee, these fans are perfect for a RAD. You are thinking the wrong numbers. CFM is only 66 but Static Pressure is Higher than most YL's and on Par with Noctuas. At 3.53mmH20 these fans are awesome for Rads and Heatsinks.
ST
www.realhardwarereviews.com
  #254 (permalink)
Old March 2, 2010, 07:59 AM
lol yah ill start overclocking. Just making sure all my bases are covered. What would you all recommend for a powerful second fan for the hyper 212 plus. I dont care about noise as it actually helps me sleep at night :-P
  #255 (permalink)
Old March 2, 2010, 08:30 AM
went with 2 of these to replace the fans on the cpu cooler.
Newegg.com - Scythe DFS123812-3000 "ULTRA KAZE" 120 x 38 mm Case Fan - Case Fans
  #256 (permalink)
Old March 2, 2010, 08:40 AM
Wow that's a lot of airflow. I hope you have an extra PWM slot on your mobo so you can control their speed or else they are going to be very loud!
  #257 (permalink)
Old March 2, 2010, 08:48 AM
gingerbee's Avatar
thanks ST i will give them a try
  #258 (permalink)
Old March 2, 2010, 09:39 AM
It will sound like a f22 raptor at boot up or the airflow could rip a hole in the space time continuum
  #259 (permalink)
Old March 2, 2010, 10:39 AM
Absolutely excessive given the nature of the actual cooler.
Something like those on a CU True I could see, but not a 212+ .
My thoughts at least.
ST
  #260 (permalink)
Old March 9, 2010, 01:46 PM
I found the 3 line thermal paste to be the most effective. Heres my temps for this cooler.
Cooler Master V10 CPU Cooler Review Comment Thread AkG Air Cooling 60 October 22, 2011 01:52 AM
Cooler Master V8 CPU Cooler Review Comment Thread AkG Air Cooling 37 June 15, 2009 10:37 PM
Cooler Master Hyper N520 CPU Cooler Review Comment Thread AkG Air Cooling 3 June 8, 2009 07:54 PM
