  #231 (permalink)
Old February 12, 2010, 06:55 AM
SKYMTL's Avatar
HardwareCanuck Review Editor
Let us know how it performs on your chip.
  #232 (permalink)
Old February 12, 2010, 09:56 AM
I have the CM Hyper 212 + and it keeps my i7 860 under 70c while running prime 95 small ffts. It is overclocked to 3.8ghz with 1.3vcore
  #233 (permalink)
Old February 17, 2010, 11:10 AM
Hey guys, I just got a couple of CM R4 fans from NCIX (thanks AkG) but I am not sure if I have them set up the right way. Should I have both fans so the backs of them are up against the heatsink with the front visible or should I flip the one nearest the back case fan and have the back part visible? Oh, and one other thing, since the fans are only 3 pins is it ok if I connect one to the CPU fan header? Thanks again, I'm just a little confused with what push/pull means.
  #234 (permalink)
Old February 17, 2010, 11:40 AM
AkG's Avatar
AkG AkG is offline
Hardware Canucks Reviewer
If you closely on the sides of the fans, there will be little arrows. One shows direction of the blade and the other direction of the air. Have both fans setup so the arrows on both are pointed in the same direction (e.g. both fans arrows point towards the back of the case). That way one push's air into the fin array of the cooler and the other sucks it out and pushes it away from the cooler.
  #235 (permalink)
Old February 17, 2010, 01:04 PM
Hi i just had a quick question. i have a msi am3 mobo and amd 965...i just installed the cooler master hyper 212+ cooler and was wondering if anyone could post some shots of the actually mounting nut and where it screws in. I have a gap between the cpu side and the mobo....in another install topic on this forum it shows it almost flush with the board. I couldnt get it to tighten anymore without the nut spinning and holding it was impossible. Did you all use a wrench or something to keep the nut from spinning in order to tighten it more? My biggest worry is tightening it to much and the screws from the brackets not being able to reach/and or crushing the cpu. Right now it seems secure and good but it looks nothing like
Coolermaster Hyper 212 Plus AMD Installation & Clearance
those look flush on both sides and with the screw almost completely through the nut...flush.
Any help would be greatly appreciated...this will be the 3rd time yanking this board out to fix this.
  #236 (permalink)
Old February 17, 2010, 01:54 PM
sswilson's Avatar
Can you take a pic of your install?
As far as securing the nut while you tighten the screw... didn't you get a nut driver with the cooler? If not, then yeah, you're going to want to use a wrench (or socket) to secure it for proper tightening.
  #237 (permalink)
Old February 19, 2010, 09:03 PM
ok i finally got windows 7 in and installed. what programs should i do to run tests on temps, stability of overclocks etc. right now doing nothing in "amd overdirve app it says i'm doing 33 degrees celsius...sounds horrible. going snowboarding then ill be back to rip out the heatsink and make sure i do it right this time. ill do the grain of rice method and make sure its fastened. question would be is it possible to overtighten the heatsink to the mounting screws or is there a built in stop mechanism.
again thanks
  #238 (permalink)
Old February 20, 2010, 12:00 AM
sswilson's Avatar
33c at idle doesn't sound absolutely horrible. what are your room temps?
For monitoring temps on amd chips I use coretemp.
  #239 (permalink)
Old February 20, 2010, 12:54 PM
is it okay to match a r4 with the blademaster? or should I be getting 2 of the same?
Intel i7 6700k (4.6 ghz) w/ Corsair H100i V2
EVGA 1070 SC
2x8GB GEIL Super Luce 2400hz
500gb SG + 2TB WD20EARS + Intel 300 240gb
Corsair TX650W
Asus Z170i Pro Gaming
Corsair Air240
  #240 (permalink)
Old February 20, 2010, 02:07 PM
gingerbee's Avatar
are the r4 any good for rads? looking for new fans thanks ahead of time fro anyone hint hint akg ha ha
Cooler Master V10 CPU Cooler Review Comment Thread AkG Air Cooling 60 October 22, 2011 01:52 AM
Cooler Master V8 CPU Cooler Review Comment Thread AkG Air Cooling 37 June 15, 2009 10:37 PM
Cooler Master Hyper N520 CPU Cooler Review Comment Thread AkG Air Cooling 3 June 8, 2009 07:54 PM
