Greetings as I'm new here. Love the site and the thoughtfulness of the reviews. Beaver FTW.
I'm posting this as I've read the reviews of the 212 Plus, as well as all the corresponding comments/debates regarding it.
In need of a cooler, and in the GTA, I decided the 29.95 price point negated the arguments regarding the results possibly being skewed. I figured, worst case, I'd run 10 degrees higher than the results indicated in the review/other users.
I am very much average joe, however, my results are far worse than what any of this thread would indicate.
For starters, Im running an i7 D0 920 on a rampage II Gene in a large, airy, dell 730x Chassis, and I'm guessing my ambients are a cool 19-22c. (I like it chilly).
What I do know is that my chip does 200x20 or 211x19 (4.0x ghz) stable at 1.24v. 500 passes of LinX, 30 hours prime. HT ON, Speedstep enabled. QTT 1.3v, Everything else at default (not auto) except DRAM, 1.6v. Im running generic Samsung HCF8 DDR3 (1066) Which happily do 8-8-8-24 at 1600+ mhz @ stock, but 1.6v is needed at anything above.
My temperatures are absolutely ridiculous. Running linx, I'm seeing 100c, 94c, 94c, 86c. (coretemp).
A 14 degree variance? I understand that a variance of 5-7 degrees is normal, but 14c?
Im using As5, and have tried several thermal paste application methods. I've remounted this cooler SEVEN times. I've tried using push-pull with a similar coolermaster fan I happened to have on hand. No difference at all.
I'm also able to touch the base of the cooler without having to immediately stick my finger in my mouth. The whole heatsink barely feels warm at all. The pattern of the thermal paste indicates decent coverage.
Idle temperatures seem normal, in the 37-42 degree range with the fanspeed ramping down. (Speedstep is enabled). At stock settings, under max load (Linx) the temperatures seem much more in line, with a much smaller varience between core 0 and core 3- about a 5 degree difference, with core 0 reading 55-58c.
I've tried other coolers. The v8 (garbage IMO, the mounting system sucks worse than any cooler Ive ever seen) and my temperatures are +/- 2-3 degrees.
Also tried the Stock Foxconn 4 heatpipe cooler/shroud/92mm fan (pretty hefty cooler) which came with the stock 730x config. The base is horrible, it's warped, but it produced slight better results before I stripped the backplate after countless mounting attempts.
What the hell is going on here? Is my CPU shooting out incorrect temp readings? Ive used several motherboards (EVGA classified, P6T) have gone through several Windows 7 installations, etc. All temp monitoring utilities spit out the same temperatures (Speedfan, realtemp, coretemp.) I'm only using 1.24v to get 4.0 ghz stable, which I feel is VERY reasonable.
Some insight please!
*edit* It may be worth noting that the 730x is a non traditional chassis- The motherboard is oriented upside-down.
Reason: forgot to mention..
