  #171 (permalink)
Old August 28, 2009, 06:54 AM
stoanee's Avatar
Originally Posted by kuddles View Post
Assuming my case has good airflow, would this cooler be decent enough for my purposes?
Yes.
I have no plans to overclock it beyond the 3.4 range
IMHO If you go into the higher ranges, say 4 ghz, (one thing leads to another) you would be better served by a more aggressive cooler.
  #172 (permalink)
Old August 28, 2009, 06:55 AM
SKYMTL's Avatar
HardwareCanuck Review Editor
Yes, I think so.
  #173 (permalink)
Old August 28, 2009, 10:00 AM
kuddles's Avatar
I suppose I should have just looked at the post immediately above me to get the answer. He's even using the same case as I am. Hyper 212 Plus it is, then.
Your favourite game of last year was over-rated, generic and contained poor level design.
  #174 (permalink)
Old August 28, 2009, 12:32 PM
Arinoth's Avatar
I'm comfortably at 3.8GHz for my i7 920 (C0 so i gotta have higher Vcore then D0)with the stock fan. I eventually plan to push-pull to help lower the temps a few degrees.
  #175 (permalink)
Old August 30, 2009, 11:17 PM
burebista's Avatar
More normal results for high TDP.
For me TRUE clone (Cogage Spirit) looks more appealing for serious OC and less money than the original.
  #176 (permalink)
Old August 30, 2009, 11:24 PM
Arinoth's Avatar
Can't say i can trust/believe those results burebista as per results i've gotten myself. I am get 25C ambient, at 3.91GHz with stock fan on it and i don't go over 75C. Maybe they didn't mount it properly or use enough thermal paste.
  #177 (permalink)
Old August 30, 2009, 11:39 PM
burebista's Avatar
Linpack? 1.320V Vcore? 27°C ambient? :)
  #178 (permalink)
Old August 31, 2009, 06:45 AM
SKYMTL's Avatar
"Normal"? Haha.
27°C is not normal ambient temp
Neither is Linpack an accurate representation of even a worst-case scenario when it comes to a load scenario. Even my Lightwave and Accurender programs don't heat up the CPU as much.
In all reality, "normal" is just a figment of people's imagination since everyone's situation is different. When it comes to ambients the best thing a reviewer can do is to try and encompass as many people's conditions as possible and test at a standard room temperature (anywhere between 20°C to 25°C).
  #179 (permalink)
Old August 31, 2009, 06:58 AM
burebista's Avatar
Normal for results SKY. As I said countless times that HDT heatsink is not able to cope with top heatsinks in high/very high TDP area. That's all what I want to say in my posts here.
  #180 (permalink)
Old August 31, 2009, 07:23 AM
SKYMTL's Avatar
And as I have said countless times before: you and I are of different opinions about HDTs.
Cooler Master V10 CPU Cooler Review Comment Thread AkG Air Cooling 60 October 22, 2011 02:52 AM
Cooler Master V8 CPU Cooler Review Comment Thread AkG Air Cooling 37 June 15, 2009 11:37 PM
Cooler Master Hyper N520 CPU Cooler Review Comment Thread AkG Air Cooling 3 June 8, 2009 08:54 PM
