  #151 (permalink)
Old August 5, 2009, 01:52 PM
stoanee's Avatar
Pic updated, will pull cooler off later and report. Still benching my overclock.
heatware
  #152 (permalink)
Old August 6, 2009, 03:55 PM
Arinoth's Avatar
i am VERY impressed with this cooler, ambient temp in my basement is from 22-25C and never saw it constantly go over 75C, it did peak a few Cs higher at the max but while i am folding 4 vmware instances i see it go the highest fluxate 74/73C for Core 1, Core 2 is 72/70C and Cores 3/4 are 68-70C. Worth more then the 30$ spent on it.
Here I am: here I remain
  #153 (permalink)
Old August 6, 2009, 06:19 PM
sswilson's Avatar
What were you using before? Do you have any temps as comparison?
Sounds like you might have a hotter chip than the ones we've seen results on so far.
  #154 (permalink)
Old August 6, 2009, 06:25 PM
Arinoth's Avatar
I was using the stock heat sink before, which was giving me 76C-74C temps at stock speeds (with intel turbo enabled as well). I am happy to see that i can be at the same temperature (a degree or two cooler actually), running 1 .2GHz faster and went from 1.8k to 2.4k ppd per core, and only for 30$ i'm very happyw ith it
edit: i think my ambient temp is closer to around 25C
  #155 (permalink)
Old August 8, 2009, 02:45 PM
stoanee's Avatar
Results so far I7 @ 3.6 ghz idle & load. Push fan only,
NCIX.com - Buy Scythe Slip Stream Kaze Jyuni 120MM Fan 1200RPM 68.5CFM 24DBA - SY1225SL12M In Canada.
Cooler reseated, Corsair ram fans removed, 26.6C ambient.
Name:  Idle 3.6 ghz.jpg
Name:  I7 3.6 ghz load.jpg
heatware
  #156 (permalink)
Old August 19, 2009, 12:04 PM
stoanee's Avatar
Okay it took me while but here are my results CoolerMaster Hyper 212+ vs Prolimatech Megahalem. The rig is the I7 in my sig @ 4ghz on a tech station with ambient 20-24C. Will only post load temps because idle showed hardly any differences. All load temps were obtained by using 8 instances of Prime 95 small fft. (hyperthreading enabled)
Load with 212+ with stock fan in push=75-74-70-71C
Load with 212+ with stock fan in pull and Scythe "SLIP STREAM" 120mm Case Fan 110 cfm) in push=73-73-68-68C
Prolimatech Megahalem with single Scythe 110 cfm fan (same as above) in push=69-68-67-67C
Prolimatech Megahalem with Scythe 110 cfm fan in push and a Scythe 68 cfm fan in pull =67-67-66-66C
The noise is actually tolerable considering the tech station is right beside me.
heatware
  #157 (permalink)
Old August 19, 2009, 12:50 PM
SKYMTL's Avatar
HardwareCanuck Review Editor
What about CM 212+ w/Scythe 110CFM?
  #158 (permalink)
Old August 19, 2009, 02:43 PM
stoanee's Avatar
I did not test that on the tech station, but I think it would drop the temps a couple of degrees. I originally had the I7 inside a case in a mediocre ventilated spot and when I replaced the Coolermaster fan on the 212+ with the 110 cfm Scythe fan the temps dropped by 2-3 degrees.
I did not use any of the data from those tests due to the less than optimal placement of the case (under a desk). When I transferred the I7 to my tech station the temps dropped 8-10C just by switching locations. I had 1-120mm & 1-100mm case fan exhausting and 1-100 mm fan blowing to the cpu from below the DVD burner with the side of the case off. The supplied fan with the 212+ is actually pretty good. The Megahalem temps were all taken on the tech station.
heatware
  #159 (permalink)
Old August 19, 2009, 08:40 PM
hey stoanee, thanks for taking the time to do this and sharing it with us. Very interesting indeed. Most telling was this bit:
212+ /w dual fans vs PM with 1 fan(same fan as 212+) - and the results speak for themselves. Epic.
Are you planning on doing anymore comparisons with other HS or maybe with a wc setup...I think I recall you might switch to wc?
  #160 (permalink)
Old August 19, 2009, 10:03 PM
stoanee's Avatar
Yes, gonna go water next. probably a swiftech cpu loop only.
heatware
Cooler Master V10 CPU Cooler Review Comment Thread AkG Air Cooling 60 October 22, 2011 01:52 AM
Cooler Master V8 CPU Cooler Review Comment Thread AkG Air Cooling 37 June 15, 2009 10:37 PM
Cooler Master Hyper N520 CPU Cooler Review Comment Thread AkG Air Cooling 3 June 8, 2009 07:54 PM
