Old July 7, 2009, 10:27 PM
Default Looking for a 92mm fan to replace stock one
I am looking for a 92mm fan to go on my Vendetta 1 CPU Cooler
to replace my stock one. Persionaly I was looking at the Scythe S-FLEX SFF92C as I have heard good things about the 120mm versions. Does anyone have any sugestions.
thx
Old July 8, 2009, 05:54 PM
Soultribunal's Avatar
Will a 120mm fit in place of the 92mm one?
Personally if a 92 is what you can fit, I know Noctua Makes them.
NCIX.com - Buy Noctua NF-B9-1600 92MM Ultra Quiet Cooling Fan 1300-1600RPM 41-64M3/H 7.9-17.6DBA Molex - NF-B9-1600 In Canada.
Or
NCIX.com - Buy Arctic Cooling Arctic F9 Pro PWM 92MM Fan 700-2000RPM 35CFM FDB - F9PROPWM92MM In Canada.
Something a little Cheaper.
Regards,
ST
Old July 8, 2009, 06:32 PM
jcmaz's Avatar
aren't there adaptors to fit a 120mm to a 92mm slot. If you did that, wouldn't you get a way higher CFM???
-Plato
Old July 8, 2009, 10:24 PM
Well the Vendetta 1 CPU Cooler has them little rubber things that fit into the screw wholes of the fan (see pic)......If there is an adaptor I was not aware that one existed could some one link it please.
Old July 9, 2009, 12:01 AM
chouchou's Avatar
a nice gelid 92mm worked great on my tj-07 and their 2x 92mm exhausts heres the link:
NCIX.com - Buy GELID Solutions GELID Silent 9TC 900-2000RPM 92MM Thermal Control Fan 37.89CFM 11-23.5DBA HDB 3PIN - FN-TX09-20 In Canada.
[WTB] LF: 80/92MM to 120MM Fan Mount Adapter azn_outlaw Buy/Sell & Trade 1 March 7, 2009 10:30 PM
Replace stock white pads with Sekisui? werty316 Video Cards 1 December 6, 2008 12:28 PM
Noctua NF-B9 92mm Fan Review Hardware Canucks Air Cooling 0 April 30, 2008 09:24 AM
92mm fan grills James_8970 Cases 0 April 6, 2008 06:54 PM
Noctua presents NF-B9 92mm fan. Scotch Tape Press Releases & Tech News 3 February 6, 2008 11:26 PM
