Old July 1, 2009, 02:26 PM
CORE's Avatar
Default IFX-14 Compatibility
Hi Guys,
Uhmm.. I was wondering if the thermalright IFX-14 CPU HSF is compatible with eVGA 780i SLI FTW mobo and NZXT Tempest case? Are there any clearance issue between mobo and CPU HSF or case and CPU HSF?
Thanks
Old July 1, 2009, 02:43 PM
3.0charlie's Avatar
It's huge. I had one. Be extra careful of the dimensions, and where is the CPU located on your board.
Hydro-Quebec is salivating...
Old July 1, 2009, 03:29 PM
CORE's Avatar
CPU is located on top of the board and left of DIMM slots
Old July 1, 2009, 05:05 PM
3.0charlie's Avatar
I know that, that's the typical location. I meant the distance between the CPU and the edge of the board, in relation to the top of the case once the board is installed. The HSF is so large that it extends past the edge of the board. And it may foul on the top of the case once the board is installed.
IFX-14 90-degree rotation. CMetaphor Air Cooling 8 February 6, 2009 02:50 PM
IFX-10 or other CTA Air Cooling 13 December 12, 2008 07:23 PM
Re: Thermalright IFX-10 review Caznoob Air Cooling 18 May 6, 2008 07:18 PM
IFX vs HR-06 vs ExtremeX kcksteve Water Cooling 4 February 22, 2008 08:03 PM
