<~----> Push-Pull CPU HSF Config Question - Hardware Canucks
Old June 30, 2009, 09:51 AM
CORE's Avatar
TechWiki Moderator
Default Push-Pull CPU HSF Config Question
Hi guys,
Heres my question. What if i plan to use a push-pull configuration setup on my cpu cooler but the two fans differ in speed(one is 1000rpm and one is 2000rpm), will the 2000rpm wear down my 1000rpm fan?
Old June 30, 2009, 10:48 AM
CMetaphor's Avatar
Quadfather
If you're going to do that then then I'd suggest using the Lower RPM fan as the "pull" fan and the higher one as the "push" fan. In this way, the higher rpm fan (presumably with higher static pressure as well) will have an easier time pushing air through the HSF than the low Rpm one would, and the low RPM can assist by pulling the hot air through the hsf as well. Just my $0.02.
Old June 30, 2009, 06:40 PM
486's Avatar
486 486 is offline
Instead of push pull, simply use spacer on your back fan so it is closer to your heatsink. Given that your heatsink fan is pushing air to the back, you get the same result with one less fan (less noise pollution).
Silverstone TJ-08E
Seasonic X-660
Asus P8Z77-M Pro
Intel i7-3770
Kingstone HyperX 2 x 8GB
Crucial M4 256GB + 128 GB
Sapphire Radeon HD7970
Nec Multisync LCD2690WUXI
Old July 2, 2009, 04:53 AM
Jackquelegs's Avatar
Originally Posted by CORE View Post
Hi guys,
Yeah it will. Worst case scenario it'll negatively impact the performance, as the slower fan will act as a restriction, while spinning faster than supposed to.
Iapetos
Zephyranthes
Questions about push/pull Cowboy Water Cooling 16 June 10, 2009 02:46 PM
Push/Pull on S1283 nckid4u Air Cooling 11 April 26, 2009 10:09 AM
Push/pull fan question kruzn4evr Water Cooling 25 April 20, 2009 02:36 PM
TRUE Push / Pull Question rjbarker Air Cooling 12 March 21, 2009 11:54 PM
Push vs Pull on a Rad? Supergrover Water Cooling 10 October 16, 2007 07:13 PM
