Old June 25, 2009, 08:11 PM
Default idea for cooling... suggestions?
Have you ever been in the super market and see one of those little freezers on wheels that open from the top? They usually have novelty ice creams or whipped cream... things like that.
Well my friend is the dairy manager at a super market and the store makes him throw away those freezers every couple of months for new ones. He took one of the cooling units from inside the freezer and we have been trying to figure out a way to mod a case using this unit.
my concern about using it is that there might be some kind of condensation which could build up in the case, and turn to ice. what we were thinking about was getting a cheap case, and taking off the right side panel, drilling a hole to line up behind the 5.25 bays, and then making a box out of sheet metal or something and bolting it to the side of the case covering the hole and see if there is any condensation inside the case.
anyone ever try anything like this? do you think it could work?
Old June 25, 2009, 08:18 PM
Soultribunal's Avatar
Those Freezer Units use Freon or other types of Gases to cool. Unless you have percisce control over the unit, I wouldn't Risk it.
See the ThermalTake Xpressar.
Its that concept Already.
ST
www.realhardwarereviews.com
Old June 25, 2009, 09:04 PM
honestly it looks like a giant heatsink that gets super cold, but there is no freon in the unit.
Old June 27, 2009, 07:14 PM
Silvgearx's Avatar
seems like a good idea.
I don't see how condensation could happen if you clean up the box.
and from reading from your opening post, your gonna get a cheap case, so i am guess there won't be any liquid cooling involve. i think your fine
Try it out with an ancient computer for now, if nothing happens in a month its all good.
Nice innovative for some summer work
Old July 21, 2009, 07:48 PM
mattydies's Avatar
Sounds like something fun to play with. But sadly condensation is VERY possible (I am A/C certified for automotive applications). You should have 2 "rads" one that gets hot and one that gets cold. Condensation is a VERY REAL concern, you could try running it with some old hardware, or even without any hardware to check about the condensation. Maybe you end up having a fan push cold air into the case. Maybe it passed through something to catch the condensation.
It sounds like it would be very interesting.
IF you open any coolant lines it will escape and I don't care what anyone says its toxic (just more - R12 - freon, or less - R134A, or others) so DONT BREATHE IT!
Have fun and let us know what you do
What a great idea! The MAX Power Supplies 7 April 7, 2009 10:19 AM
I hate it when I get idea's.... TwystedMonkey Off Topic 4 June 28, 2008 01:39 PM
8800GTS G92 water cooling -- any point/suggestions? sinephase Water Cooling 6 June 16, 2008 05:10 PM
Water Cooling friendly case and parts suggestions Cardboard box with DSL Water Cooling 40 March 24, 2008 11:22 AM
HD-HTPC Idea. BALISTX HTPC Systems & Software 10 March 13, 2008 05:31 AM
