Old June 25, 2009, 08:24 AM
"Quote This..."
I think you should remove it before your wife gets home.
"Quote This..."
and has a little time to kill, you.
Old June 25, 2009, 08:25 AM
Arinoth's Avatar
Bah i can't see these epic images, they are not loading for me
Here I am: here I remain
Old June 25, 2009, 08:28 AM
El_Fiendo's Avatar
Originally Posted by kruzn4evr View Post
Don't think I haven't thought about it! But I think it does more good where it is, cooling down the vreg and nb/sb was really the main goal so I think I'll just leave it alone
You can't incorporate those into the loop then hit the rad with the central air vent? I think more WC parts are in order.
Old June 25, 2009, 08:38 AM
Cowboy's Avatar
Images aren't working :(
Old June 25, 2009, 08:41 AM
kruzn4evr's Avatar
Infiniti....I'm not sure it would really help, there is plenty of exhaust with the push/pull on the rad and the rear exhaust fan, besides, if I started a project computer related this weekend with my wife starting holidays?...I might as well build myself a shack to live in while I'm at it
Squeetard....she can't kill me, it was her that reminded me about it at Home Depot so I'm off the hook on that one, not to mention she has no say about how I set up "the man cave"
Arinoth....they went poof!...I reloaded them so you should be able to see them now
El Fiendo....I figure for the cost of the Bitspower vreg and nb/sb blocks for the Classified?...this is a cheaper, dual purpose way to cool those parts, I get to keep the house cool and save on WC'ing parts!
Old June 25, 2009, 08:46 AM
kruzn4evr's Avatar
I had to reload them, they should work now, they work on this end
Old June 25, 2009, 08:48 AM
Arinoth's Avatar
Still do not see anything
  #19 (permalink)
Old June 25, 2009, 08:49 AM
Infiniti's Avatar
Nah, I meant something that contains your system, so the whole system gets nothing but a constant supply of cool air.
Also, at least there's SOMEONE on this forum that can get my name right. *it's not Infinity*
  #20 (permalink)
Old June 25, 2009, 08:51 AM
gingerbee's Avatar
not working
air conditioner and water cooling. kyle_L Water Cooling 6 May 28, 2009 08:29 PM
Air Cooling your Chipset Soultribunal Air Cooling 10 January 28, 2009 04:32 PM
Will air cooling do the trick? blogz101 Air Cooling 3 July 10, 2008 06:10 PM
What is better?Air Cooling blogz101 Air Cooling 13 July 9, 2008 03:13 PM
Air cooling for E6400 3.0charlie Water Cooling 7 October 4, 2007 06:36 PM
