Old June 21, 2009, 10:11 AM
Question which cooler for my video card?
just bought an ASUS GeForce 9600GSO. cheapest price/performance ratio i have seen in awhile. it seems that like other asus cards there is a wee bit of a heat problem.
so will one of the following fit
1.) Arctic Cooling Accelero Twin Turbo VGA Cooler
or
2.) Arctic Cooling Accelero Xtreme 9800 VGA Cooler
thx for advice
rob123:help:
Old June 21, 2009, 10:56 AM
JD JD is offline
Arctic Cooling TwinTurbo supports the 9600GT, though still I can't say it'll fit on the GSO for sure.
You could also try and find this: Arctic Cooling L2 Pro since it seems a bit more generic with support, lists 9600 so I'd guess the whole series.
Fairly sure the Xtreme 9800 will NOT fit since it was only designed for the 9800GTX.
Old June 21, 2009, 12:05 PM
jcmaz's Avatar
How bout the passive S2 from Arctic Freezer or the Scythe Musashi: Scythe Musashi VGA cooler review
coz someone in this forum was sell 8800GS w/ this heatsink. 9600GSO and 8800GS are nearly the same thing.
-Plato
Old June 21, 2009, 08:13 PM
JD JD is offline
They might work too. All semi-universal ones.
Best way would be to pop off the heatsink on your 9600GSO, measure the mounting holes and look at the surrounding components to see if anything sticks up. With that data, you should be able to make a choice on something that will fit.
[WTB] Sound card and wc video card hausner Buy/Sell & Trade 17 August 11, 2009 01:59 PM
WTB: Video Card/Sound Card/Hard drive - Look here if u gotz some ! Flintblade Buy/Sell & Trade 4 December 4, 2008 10:27 PM
Video Card memory 512 Available video memory 1268 mb? TwystedMonkey Troubleshooting 4 August 24, 2008 06:07 PM
WTB PCI-E Video card with Video out Taichan Buy/Sell & Trade 0 June 9, 2008 08:17 PM
