Old June 16, 2009, 04:57 PM
jcmaz's Avatar
Default Best air cooler for under $40
Hi,
I'm in the market for a new air cooler for my AMD 5200+ b/c it idles @ 55 degrees. I have looked at the OCZ Vendetta 2 and the Xigmatek S1283, but wat other options are there? and which one the is the best for the buck.
I plan on blowing all the heat up the psu and out the case. i have a small intake fan on the side and a semi useless 120mm fan blowing at the HDs and a ghetto 80mm fan on my 9600GT blowing at the northbridge.
-Plato
Old June 16, 2009, 05:05 PM
gingerbee's Avatar
sunbeam core contact or the raven
Old June 16, 2009, 09:35 PM
jcmaz's Avatar
Moar help plz.
-Plato
Old June 16, 2009, 09:46 PM
JD JD is offline
The two you suggested yourself are the best ones IMO. And well there's tons of variants that are all based directly off the Xigmatek.
Old June 17, 2009, 04:12 AM
gingerbee's Avatar
+ 1 to that mate
Old June 17, 2009, 06:16 AM
Soultribunal's Avatar
If you can find it with the MIR the ZEROTherm FV - 120 is a really respectable cooler in and around that price range.
Its simple but very effective, and it competes with a lot of the higher end coolers out there.
My thoughts at least,
ST
www.realhardwarereviews.com
Old June 17, 2009, 07:46 AM
stoanee's Avatar
Ziggy is easier to install than the OCZ.
heatware
Old June 17, 2009, 10:19 AM
Thund3rball's Avatar
I've got the Sunbeam Tuniq Tower 120 on my 5000+ BE and the side of my case is always off. Can't remember my temps but it looks fo-shizzle! :)
"this is not troll. this is real deal!" - hohohee
Desktop:
See the drop down!
Laptop: Dell XPS M1530 \\ T7500 2.2GHz \\ 3GB 667 \\ 6 Cell \\ 8600M GT \\ 200GB 7.2K \\ WSXGA+ \\ Bluetooth/Wireless \\ MS Blue Track Mini \\ Vista Ult. (RED)
HEATWARE
Witch Air Cooler??? jcmaz Air Cooling 10 June 15, 2009 08:49 PM
[WTB] 3870x2 Air Cooler Black_Ice-Dragon Buy/Sell & Trade 0 June 11, 2009 04:06 PM
[WTB] cpu cooler(LGA 775) and air cooler for 9800gt j-ronde Buy/Sell & Trade 0 March 11, 2009 10:06 PM
Best OCing Air Cooler? -POLL- CMetaphor Air Cooling 20 March 3, 2009 08:03 AM
