Old July 7, 2009, 12:29 PM
I have a brand new True Black forsale if your interested I can cut you a good deal. I bought it planning on using it for my workstation build ,but its not compatible with the motherboard im using. Anyways 65 shipped brand new in box. LMK
Old July 7, 2009, 09:38 PM
steers's Avatar
TRUE 120 for performance, Noctua NH-U12P for silence. If neither of those are available, I've used the Cooler Master V8 in a couple of builds recently with pleasant results.
Old July 8, 2009, 03:21 AM
NightRain's Avatar
Got my Noctua setup and couldn't be more happy. System is running much cooler at 3.7GHz then it was at stock 2.67GHz with Intel cooler. Money well spent.
Lian Li PC-V1010B : Dell U3011 30" LCD : Dell U2311 23" LCD : Asus P6T Deluxe X58 : Intel i7 920 @ 3.5GHz : OCZ DDR3 12GB @ 1483MHz 8-8-8-24 : Noctua NH-U12P : 2x MSI 6970 Lightning CF : Auzentech X-Fi Forte 7.1 : 2x Samsung DVD-RW : Samsung DVD-ROM : OCZ Synapse 64GB Cache SSD : WD 1.5TB Black HDD : 2x WD 1TB Black HDDs : Corsair HX1000W : Cyborg R.A.T. 9 : Razer BW Ultimate Keyboard : Energy C-200 /w Yamaha RX-V667 AVR : Sennheiser HD555 Headphones : APC UPS XS 1200 : WIN 7 ULT 64
Old July 8, 2009, 08:01 AM
stoanee's Avatar
Nice clean rig you got there night!!
heatware
Old July 8, 2009, 08:31 AM
artistpavel's Avatar
I got Vendetta 2, because it showed better performance on HWC charts and I'v been blown away. Got Q6600 OCed to 3.6 and temps never go over 59C on load, basically makes heat problem nonexistent. and Q6600 is the old 65 nm technology compared to i7.
х58forLife
Heat sink comparison Bones Air Cooling 11 March 27, 2009 05:07 PM
CPU Heat sink WolfBane Air Cooling 4 March 8, 2009 09:58 PM
best air cooling heat sink to use for the E8400? Gameplaywarrior Air Cooling 27 December 8, 2008 10:33 AM
what is a decent air heat sink Shadowmeph Air Cooling 13 January 8, 2008 06:46 PM
Modifying my CPU Heat Sink??? mattydies Water Cooling 8 June 25, 2007 09:03 PM
