Old June 14, 2009, 06:55 PM
that looks like an ocz vendetta, which i have, those type of coolers benifit from more air pressure?
Old June 14, 2009, 09:58 PM
Realityshift's Avatar
Honestly your best bet to get more air into your case is just to get a dremel and cut out the fan grill so that theres nothing blocking the air from coming/going, this will also help alot with noise.
EDIT: all air coolers benefit from high static presure as your trying to get the most amount of air through small spaces quickly, the faster the cool air flows across the fins the more cooling potential the heatsink has. However you will not really see a huge amount of difference (maybe 2c) on a single fan heatsink and maybe (4-5c) on a dual fan. Where high static presure really shows its glory is in multi fan setups aka water cooling rads. Tripple rads have 3-6 fans flowing air across a much greater surface area then a normal air cooler so you see alot more difference from fan speeds and presures.
Case in point, I have a xigmatek HDT-1283, pretty similar to the OCZ vendetta 2 in cooling performance. the stock fan was like 38CFM and pretty decently high static presure, I just installed an aerocool 89CFM fan and it dropped my CPU temps by about 2c, running a hollow fan inbetween it and the heatsink dropped my temps by between 4 and 5c (from the original xigmatek fan).
The Builders Hammer
Old June 14, 2009, 09:59 PM
I dont know why you guys seem to think noise is an issue for me, i presonally dont care if its loud or not.
What is a dremel btw?
Old June 14, 2009, 10:04 PM
A tool used to cut/grind/sand stuff. Quietness is just an added benefit I wasnt saying it mattered to you just that you would also see it as a bonus ;)
The Builders Hammer
Old June 14, 2009, 10:06 PM
Oh.. powertools start straying out of my comfort zone, i mean i wish i could find somoene to mod my side panel so it could hold another fan, but im not comfortable doing it myself.
zalmaan 6 fan, fan controller quikgp Peripherals 4 May 29, 2009 09:32 PM
4870 fan: Catalyst auto-fan is too aggressive Bucklaz Video Cards 4 January 7, 2009 12:21 PM
delta distance : (fan to rad) && (fan to grill) elninio Water Cooling 13 July 12, 2008 03:03 PM
FS: fan hDD cage w/ 120mm lighted fan, cpu funnel, pentium 1 elninio Buy/Sell & Trade 7 June 20, 2008 12:18 PM
Cosmos 1000 VGA Fan Duct or Cosmos S 200mm fan? no_pulse Air Cooling 0 June 10, 2008 05:57 PM
