Old June 14, 2009, 09:40 AM
jcmaz's Avatar
Default Witch Air Cooler???
Hi
I'm looking for an aftermarket AM2 heatsink to cool my AMD 5200 @ 55-60 degrees. And some thermal paste if the thing doesn't have it.
Witch one should i use?
I have around 30-40 dollar budget.
Scythe Reeven Direct Touch Heatpipe CPU Cooler LGA775 AM2+ S478/939/754/940 92MM Fan 2500RPM 31.07DB
Arctic Cooling Freezer 64 PWM AM2 S754 S939 S940 900-2200RPM 40CFM 4PIN Heatsink Fan
or other stuff
-Plato
Old June 14, 2009, 11:25 AM
gingerbee's Avatar
with that budget i would get the xigmatek 1283 but if i where to chose out of those too well then it would be the raven
Old June 14, 2009, 11:50 AM
jcmaz's Avatar
do u think i could PM the Xiggy in store at NCIX for 34 bucks from Newegg?
-Plato
Old June 14, 2009, 12:00 PM
Perineum's Avatar
The AC F64 isn't that bad. It's small but I'm pretty sure it would hold your cpu to those temps. It's a nice easy install too.
Old June 14, 2009, 12:26 PM
keeps my 5200+ nice and cool..small case to ...plugged with dust atm, but still under 40c..
and my place is very warm...
i also agree ,simple install..
jcmaz:i think there's one in buy/sell for 15.00
http://valid.canardpc.com/show_oc.php?id=932179
"Be so good at what you do that you cant be ignored"
Old June 14, 2009, 03:29 PM
jcmaz's Avatar
I'm getting different reading. Core Temp tells me its 60/65 degrees while Everest is 42/37 degrees. WHy and which one should i believe in.
-Plato
Old June 14, 2009, 03:31 PM
geokilla's Avatar
AMD CPUs use the Tcase to measure temperature, which is the sensor that programs like ASUS PC Probe uses. Basically, it's the motherboard temperature sensor. Core Temp uses Tjunction to measure temperatures, which are inaccurate on AMD CPUs.
Go get an OCZ Vendetta 2 if you can. What cooler are you using right now?
Old June 14, 2009, 10:09 PM
jcmaz's Avatar
I'm using the crappy stock AMD heatsink. But i put a ghetto fan on top of my 9600GT to blow at the heatsink
-Plato
Old June 15, 2009, 10:04 AM
Thund3rball's Avatar
Oh I was hoping to see an air cooler that looked like a witch. Halloween build FTW!
"this is not troll. this is real deal!" - hohohee
Desktop:
See the drop down!
Laptop: Dell XPS M1530 \\ T7500 2.2GHz \\ 3GB 667 \\ 6 Cell \\ 8600M GT \\ 200GB 7.2K \\ WSXGA+ \\ Bluetooth/Wireless \\ MS Blue Track Mini \\ Vista Ult. (RED)
HEATWARE
Old June 15, 2009, 10:08 AM
Chos3n's Avatar
So an heatsink that magically removes the heat? Witch Air Cooler!
System | Ragnarok
Case Antec 900
PSU Corsair TX750W
CPU Intel Core i7 2700K 3.5GHZ
Motherboard ASUS P8Z68-V
Memory Corsair Vengeance Blue 8GB 2X4GB DDR3-1600 CL9-9-9-24
Video Card EVGA GeForce GTX 780
Sound Card ASUS Xonar DX
[WTB] 3870x2 Air Cooler Black_Ice-Dragon Buy/Sell & Trade 0 June 11, 2009 04:06 PM
[WTB] cpu cooler(LGA 775) and air cooler for 9800gt j-ronde Buy/Sell & Trade 0 March 11, 2009 10:06 PM
Best OCing Air Cooler? -POLL- CMetaphor Air Cooling 20 March 3, 2009 08:03 AM
Strategy Informer reviews Lord of the Rings: TBFME II—The Rise of the Witch-King Supergrover Reviews & Articles from the Web 0 January 4, 2007 06:37 PM
