Old May 30, 2009, 06:59 PM
somecanadianguy's Avatar
Default Fan holder for TRUE 1366
Anyone know where to find the plastic fan holders for the TRUE 120 1366?
I want another one like the one that came with it.
Old May 30, 2009, 07:47 PM
Silvgearx's Avatar
i got 1 of these to replace those little wires that comes with it. its called Thermalright U120E 120MM Fan Holder for Thermalright 120MM Heatsinks
NCIX.com - Buy Thermalright 120MM Fan Holder for U120E Series Heatsinks - FH-U120E In Canada.
Old May 30, 2009, 07:49 PM
Exactly what I was looking for...
That's what came with mine.
Thanks!
*edit*
It's not available right now
Old June 3, 2009, 05:35 PM
aviduser's Avatar
Im a fan of the wire ones, with these you cant use a 38mm fan...
I actually have one of those fan holders you could have free if you pay for the shipping.
HAF-Full
-Phenom II 940 @ 3.8 ghz
- Sapphire 5870 890/1220
- 4 ghz g.skill
- Corsair tx850w
Old June 4, 2009, 02:20 AM
Silvgearx's Avatar
good offer, but that holder takes quite a bit of space and shipping would be like $12
and yea with the holder its a pain to get it in tight cases, like the antec 300 for example, you can only have the TRUE 120 facing up and not side ways with the fan holder, but with the clips its possible to arrange the TRUE 120 anyway you want on a small case like the antec 300.
Clips has its pros and cons
Old June 4, 2009, 05:06 AM
bojangles's Avatar
I have mine in push/pull configuration and use the plastic fan holder along with an elastic band for the pull fan. Elastics are your friend. :)
Old June 4, 2009, 05:03 PM
Silvgearx's Avatar
elastic bands
they will wear out over time, the fan drops and might take out something with it
Old June 4, 2009, 05:15 PM
Tie wrap it :P
Back up - Ebay (Inik1) or Heatware
Old June 4, 2009, 05:49 PM
I don't think I'd trust elastic bands for very long.
Either way it doesn't really matter right now as I only have one fan.
I won't have the other one for a week at least.
[WTB] Heatsink for socket 1366 (TRUE or Noctua) James_N Buy/Sell & Trade 4 May 15, 2009 09:07 AM
4870 fan: Catalyst auto-fan is too aggressive Bucklaz Video Cards 4 January 7, 2009 11:21 AM
TRUE-120, need another fan mounting clip Menello Air Cooling 6 October 8, 2008 12:20 PM
FS: fan hDD cage w/ 120mm lighted fan, cpu funnel, pentium 1 elninio Buy/Sell & Trade 7 June 20, 2008 12:18 PM
I4U reviews Humanscale CPU 600 PC holder Supergrover Reviews & Articles from the Web 0 August 28, 2007 06:13 PM
