Old May 30, 2009, 12:44 PM
Gellidius's Avatar
Default BEWARE of Scythe fans!
About 1 month ago i changed the in/out std. fans (front/rear) on my Lian-li case to get better cooling, instead of quietness.
So, i bought 2 Scythe Kaze Jyuni 1900RPM/110CFM fans;
They lasted about 1 month; the front one had bearing seizure, and the rear one was already slowing down and would have been dead in a few days at most.
Case temps are always around 28C, so heat was not the factor, if you consider that the front one runs cooler than the rear one and it's the front one that died first.
I now have 2 Thermalright Stealth silent 2000RPM/80.5CFM fans installed;
they are a bit noisier than the Scythe, but they seem to push more air than the Scythe.
My cpu temps, in similar conditions, seem to be about 2-3C lower with the Thermalright fans than before.
So... the moral of this story is:
Jacques
Ego cogito, ergo deus non est.
Old May 30, 2009, 01:42 PM
JD JD is offline
Those are the cheap, low-end fans. And they use sleeve bearings. So I wouldn't expect them to last forever, but it should of lasted longer than a month.
If you had invested in the S-FLEX series that use S-FDB bearings, they'd probably still be running fine.
So I wouldn't bad-mouth Scythe as a whole, and you might be able to contact NCIX and RMA them.
Old May 30, 2009, 01:53 PM
Gellidius's Avatar
Originally Posted by jdrom17 View Post
Those are the cheap, low-end fans. And they use sleeve bearings. So I wouldn't expect them to last forever, but it should have lasted longer than a month.
1: If 1 fan had gone bad and the other one running ok, then i would not have bad mouthed Scythe, but as it happened to 2 fans, then it's not bad luck, and by telling which fan model went wrong, i did not bad mouth Scythe as a whole.
2: I would have had to pay postage to RMA them and would have gotten new ones with the same problem, and would have been unable to use the pc for weeks in the meantime.
For cheap items like fans, i think it's best to just throw them away and get something different right away.
Jacques
Old May 30, 2009, 02:23 PM
NyteOwl's Avatar
My workstation has 5 Scythe Slipstreams that have been running pretty steadily for close to a year now. No problems. On average Scythe are decent fans.
Obsolescence is just a lack of imagination.
Old May 30, 2009, 02:30 PM
gingerbee's Avatar
i have a ultra kaze that i just took out of my htpc running for almost 2 years straight i think you got lemons sorry man( Owen many ultra kaze just most are not being used right at the moment never had a problem.)
Old May 30, 2009, 04:02 PM
Gellidius's Avatar
one thing for sure: i have to learn about the different bearing qualities that can be had in fans. I don't know anything about that.
Jacques
Old May 30, 2009, 05:17 PM
Silvgearx's Avatar
i have 2 scythe fans and one of them is at least 2 years old. no problem so far :)
if you want reliability get some of these NCIX.com - Buy Noctua NF-S12B FLX 120MM Ultra Quiet Cooling Fan 600-1200RPM 49.2-100.6M3/H 6.2-18.1DBA Molex - Noctua NF-S12B-FLX In Canada.
even those noctua have lower RPM and CFM, they still can kick a 100CFM fan's ass in terms of intake and exhaust/CPU fan
Old May 30, 2009, 05:59 PM
MpG's Avatar
MpG MpG is offline
The fact that they both died like that, makes me wonder if the fans were dropped badly or crushed somehow (before you got them). As mentioned, they use sleeve bearings, which are the cheapest to make, but also the lowest quality, and the least resistant to abuse.
Old May 30, 2009, 06:04 PM
Eagle Eye's Avatar
adding to that a 6 year warranty.
Rule of thumb "you get what you pay for"
EE
Old May 30, 2009, 06:22 PM
Silvgearx's Avatar
well, i had drop my fans a few time (on the carpet), and also submerge them in running water and dry them off. they're still running like champs.
time to power wash the old P4
[FS] New Zalman fans, used Scythe and blue LED fans mhw100 Buy/Sell & Trade 15 June 22, 2009 02:32 PM
The New ATI HD4830. Buyer Beware? SKYMTL Press Releases & Tech News 18 October 25, 2008 04:16 PM
Scythe Announces Slim 100mm Case Fans MAC Press Releases & Tech News 3 June 23, 2008 01:17 PM
WTB Scythe LGA 775 retention kit SCURK1 for Scythe Ninja Copper rom0n Buy/Sell & Trade 2 June 14, 2008 11:19 AM
Corsair memory: Buyer Beware! Victor5 RAM 21 January 3, 2008 01:14 PM
