Old May 26, 2009, 09:17 PM
clone63's Avatar
Default Sluggish 12cm fan?
I've noticed that the blue led fan I have on the window of my case is a bit slow to start up when turned on and when running I can make out the blades as they move rather than the whole fan being a blur as I am used to. I have never had an LED fan before so can I see it because of the LED's or is it moving slow?
Old May 27, 2009, 01:05 AM
bovine.baron's Avatar
The speed might be temperature controlled. Your case is cool when you just start up and gets warmer after running a while so that would explain it.
Old May 27, 2009, 05:13 AM
Soultribunal's Avatar
Well, it could be a few things.
Like the Baron said, it could be temp controlled.
How do you have that plugged in? MB header? Molex Pass-Through?
Most MB's have smart fan controls for anything you plug into a Header, which could be a reason for it looking slow.
Best way to test it to make sure its okay is to run it off a Molex and see if it still acts the same way.
Regards,
ST
Old May 27, 2009, 11:15 AM
clone63's Avatar
It is running daisy-chained off another fan's molex. Could the split power be another explanation?
Old May 27, 2009, 11:20 AM
No, I've daisy Chained 7 Fans in a Tempest Together on One Molex off the PSU.
Bad Fan possibly...is it pushing a lot of air or no?
I'd say replace it, you might have a defective one.
Regards,
ST
Old May 27, 2009, 04:58 PM
clone63's Avatar
I can definitely feel air moving from it, but not as much as I expected. This is my first tower in 3/4 years (lowsy laptops) so I can't say how the 12cm contrasts to others.
Since my case temps aren't high at all I'll probably just leave it until it actually craps out or temps begin to increase.
[WTB] q6600 with fan or no fan nosebleedXD Buy/Sell & Trade 2 January 31, 2009 02:33 PM
4870 fan: Catalyst auto-fan is too aggressive Bucklaz Video Cards 4 January 7, 2009 11:21 AM
delta distance : (fan to rad) && (fan to grill) elninio Water Cooling 13 July 12, 2008 03:03 PM
FS: fan hDD cage w/ 120mm lighted fan, cpu funnel, pentium 1 elninio Buy/Sell & Trade 7 June 20, 2008 12:18 PM
Cosmos 1000 VGA Fan Duct or Cosmos S 200mm fan? no_pulse Air Cooling 0 June 10, 2008 05:57 PM
