Old May 23, 2009, 09:35 AM
I've got a "stuck" e8400..no lower than 36c.
Old May 23, 2009, 09:45 AM
BT!'s Avatar
BT! BT! is offline
Originally Posted by rjbarker View Post
Same Temps without lapping...Zalman 9700.....I'm certainly not a fan of the benefits of Lapping in most cases..the extra (or in some cases as mine vs the above quote no benefits), isn't worth the risk.
i have never lapped a cpu and dont plan on it, its flat enough that it wouldn't make much of a difference. i only lapped my true, both my true's absolutely needed to be lapped imo, the curve in it before lapping was so extreme it only made contact with about 1/4 of the processor if that.
Old May 23, 2009, 01:58 PM
Realityshift's Avatar
The lap I did on this CPU was pretty nessesary, there was a nice concave in the middle, like I said it lowered the temps pretty signifigantly, and considering the CPU is off warranty and it only takes 45 minutes of sanding to lap it I wouldnt say it was much of a risk. my xiggy on the other hand is pretty much flat, lapping it would do no good.
The Builders Hammer
idle temps for Q9550 SmogTown CPU's and Motherboards 10 May 14, 2009 10:41 AM
Temps for E8400 on W/C clearly off... Barber Water Cooling 18 April 6, 2009 10:02 AM
Post your IDLE temps! BrianHanna Cases 28 February 23, 2009 09:58 AM
what is normal idle temp for e8400 Shadowmeph Air Cooling 15 December 29, 2008 10:46 PM
E8400 Idle Temps... rjbarker Overclocking, Tweaking and Benchmarking 13 April 14, 2008 02:36 PM
