Old May 21, 2009, 08:50 PM
Default TRUE 120 idle and load temp for i7 920
i am using Thermalright Ultra Extreme 120 on my core i7 920
Oced to 3.8 Ghz at 1.25Vcore
with single fan at push around 2100rpm and 80 cfm
my idle temp is at 41 ~ 43 degree
and loaded temp is around 69 ~ 73
is the temperature normal or is it slighty high using a TRUE?
Old May 21, 2009, 09:07 PM
rjbarker's Avatar
Looks about right....i run 3.83 Ghz 202 x 19 Memory 1612 vCore 1.325v
Idle 35c - 39c
Load Max 68c
But i'm running the TRUE with 2 x 120mm 1500 RPM Scythe SFlex Push n Pull.....I originally had a single fan but found my load Temp at 4 Ghz was pushing 80c..so got the second one.
Classified Ultra SLi "Procyon"
http://i30.photobucket.com/albums/c3...2/DSC02888.jpg
http://i30.photobucket.com/albums/c3...2/DSC02889.jpg
Evga 4.2 Ghz Club....
Old May 21, 2009, 09:12 PM
Jake_HT's Avatar
That looks normal for HT on, is it?
http://jakeht.deviantart.com/
Old May 25, 2009, 09:49 PM
With my i7 920 on load with prime95 it reaches around 68, and that's at 3.5 with 1.248 Vcore. Also that's with a TRUE, attached with a Sycthe Ultra Kaze 133cfm. I've always wondered if that's kind of high, or if maybe my overclock isn't set up as good as it could be.
Computer Specs:
Intel Core i7 960 @ 3.6ghz
Gigabyte EX58-UD5
Sapphire 4870X2
3x4GB Mushkin Blackline
Corsair tx750 watt psu
WD 640gb black
Antec 1200
Thermalright Ultra 120 extreme
Old May 25, 2009, 10:08 PM
rjbarker's Avatar
^^^ Looks alright..
Old May 26, 2009, 04:56 AM
bojangles's Avatar
My D0 chip runs 191x21 (with Turbo on) with load temps as high as 78 and idle at 48. It does run quite hot, but I'm even at voltages within spec of the chip (1.2V).
Old May 26, 2009, 09:45 AM
rjbarker's Avatar
Now that the Waterblock is available for the Classified NB that seems to be the way to go....even with an additional 60mm and 40mm strapped onto the NB the Temps their are high...idling 60c in BIOS. Thiers no way I'll go to 4Ghz and run my CPU at 80c, along with 2 x 280's running at 75c load....gets way too toasty in thier.........
will be looking at W/C this fall...
Old May 26, 2009, 11:09 AM
bojangles's Avatar
Me too man. I'm actually kind of excited to get into it. I think I may just tone down my OC as well because I can play all my games more than fine at those speeds. Who knows though...
Old May 26, 2009, 11:35 AM
rjbarker's Avatar
I've tried gaming on this Classified / I7 at both Stock and 3.83...no difference at all.....the only differences are Benches.....
Looking forward to the WC as well.....have to research now as I have never WC....
Old May 26, 2009, 03:32 PM
yah i am thinknig to switch to Prolimatech MegaHalems heat sink
is it wroth it vs a TRUE 120 ?
or maybe i should just switch it to WC for the sake of slient system
putting so much fan make it really loud >_<
QX6850 idle temp? pp1111 Troubleshooting 3 April 23, 2009 09:16 AM
[WTB] WTB: Thermalright Cooler (TRUE 120/SI 128/TRU 120/TRU 90) Table21 Buy/Sell & Trade 0 February 8, 2009 02:24 PM
what is normal idle temp for e8400 Shadowmeph Air Cooling 15 December 29, 2008 10:46 PM
What's a safe load temp for an overclocked GPU? chouchou Video Cards 19 December 29, 2008 11:21 AM
just dropped my idle temp by... rob123 Video Cards 11 July 23, 2008 09:03 PM
