<~----> Dying Pentium III fan - what should I do ? - Page 2 - Hardware Canucks
Old May 19, 2009, 12:57 PM
bojangles's Avatar
Originally Posted by CTA View Post
hmm... try to use rubbers... i think there are a little gap between bottom of the heatsink and mobo...
Nice one! That made my day.
I would just grab some zip ties and plop a 120 mm fan on top of it. That would be more than adequate.
Old May 19, 2009, 12:58 PM
JD JD is offline
Originally Posted by foxman View Post
The heatsink/fan looks like this:
http://www.dansdata.com/images/cel2/assembled320.jpg
The fan casing is specially made to "clip" into the heatsink. I might post a more relevant picture of it.
If that's what it is, that's a daughter-board with a socket 370 on it. AKA, you could just buy a whole socket 370 heatsink assembly. I think most socket A ones fit as well.
Old May 19, 2009, 01:20 PM
CTA's Avatar
CTA CTA is offline
>_>
but zip ties is thicker than rubber...
NEW: customize case, hx100, i7 920, supreme hf, x58 sabertooth, 3gbx2 ram of ripjaws, xfx hd6950 CF. vertex 2 60gb, seagate and hitachi 1tb, dual mcp355 with ek rex v2, 2x koolance ar697, 2x mcr320, 6x zm-f3 fans.
OLD: cm 690, hx620, intel q9450, True Black, ga-ep45-ud3p, 2gbx2 ram of mushkin xp2 8500, xfx 285. wd caviar se16 640gb, 4x zm-f3 fans.
Old May 19, 2009, 02:26 PM
Here's some pics! All dusty and low quality! The first one is a bonus, just for your eyes. By the way, I purchased the CPU of second hands (for something like 6$, 2 years ago), originally there were a P3 667 in it. And indeed, this is a socket 370 CPU.
The heatsink is 55 mm x 60 mm x 25 mm. It's really small if you compare by today standards. (By the way, the 4th picture is a demonstration on how you install the fan on the heatsink -- you just need to push a bit further and it will "clip" in place).
Having a free fan would certainly be awesome, I'm not asking that much.
E8400 (C0) @ 3.75 GHz -- HDT-S1283
Old May 19, 2009, 03:14 PM
Soultribunal's Avatar
Okies, I'll dig through the BIn at work tommorow, those pictures and Dim's were perfect.
If I find one, its yours.
Regards,
ST
Old May 19, 2009, 03:47 PM
sswilson's Avatar
Does it have a standard fan header attachment?
If you don't have any luck finding exactly the right fan (I wouldn't bother), the great majority of AMD fans/heatsinks of that era were just screwed into the heatsink using the standard fan mounting screws so just go with the right size fan and don't bother looking for the exact mount. (The threads are just wide enough to hold onto the fins of the heatsink)
Old May 19, 2009, 04:07 PM
sswilson's Avatar
This is only a 40mm fan, but serves just as well for demonstration purposes.......
Here's the overview to give you an idea what I'm talking about.... the fan fits between the ridges at the sides of the heatsink, but is just attached to the fins using standard mounting screws.
Just a closeup of the screw......
Not the best image for the side view, but you should be able to get the idea.... so long as the mounting screw threads are slightly larger than the space between the fins it'll have no problem holding the fan in place.
Soultribunal: alright, thanks. If you find something and you want me to pay for the handling & shipping, just ask !
And the fan has a 3-pin header, like regular case fan can have.
Yeah, I get the idea. Guess it could be my "backup" solution.
  #19 (permalink)
Old May 19, 2009, 04:52 PM
Perineum's Avatar
uhmm.... edited because I'm an idiot....
  #20 (permalink)
Old May 19, 2009, 05:02 PM
You got some bulged caps on that board too.
And you really need to give that whole system a cleaning. That much dust on a ram modules could cause them to short out.
Stock 120mm fan in Antec Sonata III failed dosmond Air Cooling 1 February 12, 2009 04:59 AM
FS: fan hDD cage w/ 120mm lighted fan, cpu funnel, pentium 1 elninio Buy/Sell & Trade 7 June 20, 2008 12:18 PM
Diagnosing dying video card? RainMaker Troubleshooting 5 March 12, 2008 10:23 AM
Pentium Lives!! Pentium E2160 and Pentium E2140 Babrbarossa CPU's and Motherboards 4 June 4, 2007 04:25 AM
Heat sink and fan selection for Intel Pentium D 915... mattydies CPU's and Motherboards 6 March 17, 2007 09:36 PM
