  #21 (permalink)
Old May 20, 2009, 08:14 AM
Chos3n's Avatar
Looks like AMD isn't getting some love anymore ...
Great Review, but that heatsink is a bit pricey though... Would be worth it for those people who like to push their D0 Stepping to the limit
System | Ragnarok
Case Antec 900
PSU Corsair TX750W
CPU Intel Core i7 2700K 3.5GHZ
Motherboard ASUS P8Z68-V
Memory Corsair Vengeance Blue 8GB 2X4GB DDR3-1600 CL9-9-9-24
Video Card EVGA GeForce GTX 780
Sound Card ASUS Xonar DX
  #22 (permalink)
Old May 24, 2009, 06:52 PM
S_G's Avatar
S_G S_G is offline
Great review, awesome heatsink. Almost makes me want to go back to air cooling. It seems to benefit greatly from the increased airflow of dual fans, so I assume it'll be superb with some higher cfm and static pressure fans.
I feel I have to point out that "irregardless" is not a word, though. (page 6)
HTPC: MSI Z77A-G43 + i5-3570k@4.6 + 16GB DDR3-1600 + GTX 580 + X-Fi Platinum on water
Work: 13" MacBook Pro Retina 512GB
Old Workstation: X7DWA-N : 2x Xeon E5330 Quads @ 3GHz + 24GB FB-DIMM DDR2-800 on water
1x 8800 Ultra --> Sony GDM-FW900 + LVM-37w3se // HT Omega Striker ~ (optical) Pioneer SE-DIR800C ~+ SE-DHP800 / HD 280 Pro
  #23 (permalink)
Old June 8, 2009, 11:16 AM
Digikid's Avatar
Just to let you know....there is a typo....a funny one...in page 5.
Even just by looking at this mounting setup, you know its going to give good results. By way of good engineering, Prolimatech gas
it gives you gas as well? SOLD!!!
  #24 (permalink)
Old June 8, 2009, 12:49 PM
AkG's Avatar
AkG AkG is offline
Hardware Canucks Reviewer
welllll....I don't know about gas BUT Unicorn giggles are included :)
Good catch on the typo :)
  #25 (permalink)
Old June 16, 2009, 12:07 AM
Sheep's Avatar
Thought I might point this out.
CPU Cooler
AMD support.
They also posted this on their home page.
"Prolimatech does not condone any type of lapping done to the CPU or to heatsink base. Every Prolimatech's heatsink base is designed on a pin-point scale of how the base is to be flat and/or curved where it's needed to be. We have programed our machines to machine the surface in a very calculated way. Any after-manufacture lapping or modding done to the base will alter the design, hence negating its performance factor as well as its warranty."
Sheep
Cooler Master V10 CPU Cooler Review Comment Thread AkG Air Cooling 60 October 22, 2011 01:52 AM
Cooler Master V8 CPU Cooler Review Comment Thread AkG Air Cooling 37 June 15, 2009 10:37 PM
CoolIT Domino A.L.C CPU Cooler Review comment thread AkG Water Cooling 67 April 30, 2009 05:32 PM
Noctua U9 CPU Cooler Review comment thread AkG Air Cooling 16 October 8, 2008 10:16 PM
