-   Air Cooling (http://www.hardwarecanucks.com/forum/air-cooling/)
-   -   Should i change my cpu heatsink? (http://www.hardwarecanucks.com/forum/air-cooling/17916-should-i-change-my-cpu-heatsink.html)
MrFoxx May 13, 2009 09:45 PM
Im currently using a Zalman CNPS7500-CU LED Heatsink Fan with an e6600@3ghz, been using it for well over 2 years and i havent had any trouble with it. I just purchased a q6600, i dont know if i will overclock it, but if i do ill probably take it to 3ghz and leave it there.
Should i buy another cooler, or hang with the zalman, im also using arctic silver 5 as my thermal grese.
jcmaz May 13, 2009 10:01 PM
"If its not broken, why fix it"
MrFoxx May 13, 2009 10:05 PM
Old school words of wisdom.
Figured id ask, been on an upgrading spree this week, figured id close all my options before my credit card bill arrives and i have regrets.
MpG May 13, 2009 10:09 PM
I can't see that heatsink having any trouble with a 3GHz overclock, so you might do well to just leave things as they are.
Nademon May 13, 2009 10:41 PM
...all good advice...but you coulnd't go wrong with a Vendetta2! I LOVE mine...love love it! Usually find someone selling one for a decent price too.
(did I mention I love it?)
JD May 14, 2009 09:37 AM
Q6600's do pump out more heat than an E6600, probably close to double?
I'd personally say get a new heatsink. That's not even one of the tower Zalmans, it's a flower one without any heatpipes and such. It's 36.4C - 43.1C over ambient with a 150W heatload, which is pretty bad.
MrFoxx May 14, 2009 09:44 AM
Its the Go edition, im going to let it run for a few weeks and see, if it is a big problem ill get that vendetta.
AkG May 14, 2009 09:48 AM
If you get the Vendetta 2....splurge for the crossbow backplate ;) The newer one is i7 and 775 dual capable so its a good investment...and then no worries with the crappy push-pins which are the STD mounting setup. IMHO the ease of installation and peace of mind is worth the extra $$.
MrFoxx May 14, 2009 09:49 AM
I dont know what that is, can i get a link
AkG May 14, 2009 09:52 AM
Sure, the OCZ V2 is an upgraded clone of the Xigmatek S-1283 and uses the crappy pushpins for mounting. Here is the optional backplate for it. Better more secure mounting and better temps. :)
NCIX.com - Buy Xigmatek ACK-I7361 Crossbow Mounting Kit LGA1366 775 for HDT-S963 HDT-S1283 RS-S1283 - ACK-I7361 In Canada.
