Old May 14, 2009, 10:56 AM
Thanks, i dont know, spend 600 this wekk on upgrades, if i have any express trouble with this thing when i get it, ill look into this crossplate.
Old May 14, 2009, 02:18 PM
gingerbee's Avatar
my 9700 that was on my q6600 at one point did not handle any overclocking very well at all get yourself a xigmatek 1283 or a ven 2 are good. and the price is right for both
HDT pipes work very close to water cooling as long as your not upping the V's a lot.
Old May 14, 2009, 02:20 PM
gingerbee's Avatar
get the crossbow plate it's worth it these cooling towers are way heaver then the socket was designed to handle ( afaik right from intel specs )
Old May 14, 2009, 06:43 PM
I didnt buy that crossbow plate, i probably shouldve, installing that vendetta 2 was an ordeal. Did get a 10 degree drop on my cpu though. not even using artic silver 5, saving the last bit i have for when my cpu arrieves in a few days.
Old May 14, 2009, 06:52 PM
gingerbee's Avatar
nice temp drop. yes they are a pain to put on. there are good install guide for the push pin setup at toms. but the push pins are kinda flaky.
Old May 14, 2009, 11:02 PM
Ive had the 7700 for so long that ive gotten used to the loud fan as if it were ambient noise, not it seems like something is wrong with my pc cause i cant hear my cpu fan lol.
CPU Fan speed change? HalifaxJ Troubleshooting 10 March 12, 2009 10:21 PM
new cpu heatsink Evylldemon Air Cooling 6 November 10, 2008 03:03 PM
OCZ's Cryo-Z phase change CPU cooler Hardware Canucks Air Cooling 0 May 8, 2008 10:23 AM
Poor 6800 agp performance after heatsink change ebdoradz Video Cards 9 November 28, 2007 07:50 PM
IBM doubles CPU cooling capabilities with simple manufacturing change Babrbarossa Press Releases & Tech News 3 March 27, 2007 08:36 AM
