-   Air Cooling (http://www.hardwarecanucks.com/forum/air-cooling/)
-   -   Realy low temp needed (http://www.hardwarecanucks.com/forum/air-cooling/17824-realy-low-temp-needed.html)
martin_metal_88 May 11, 2009 07:21 PM
Hi guys, there is a pretty hard one for you. I actually want to push to the limit one of my friend Q9550. He is going to put it in a HTPC and he want me to see how good the chip is by OC it to the limit ( that air can go ) So I ask you about how to keep a chip OC about...I think I can reach 4.2 maybe...pretty low for OC to be good. It will be plug under my Vandetta 2 but I need much more cooling. I can't use water because my only kit is already under not in my house...erhhh...Well if you have any tips tell me;)
Thx alot HWC
cadaveca May 11, 2009 07:26 PM
CPU-LN2 Liquid Nitrogen Evaporator (CPU) - Water cooling systems, pc liquid cooling kit, cpu, video card, hard drive
JD May 11, 2009 08:08 PM
Hehe, +1
Though for air, best you can do is get like a TRUE (Thermalright Ultra 120 Extreme) and strap on a nice 200+ CFM Delta to it.
MpG May 11, 2009 08:22 PM
Liquid metal thermal paste - I've been finding this stuff to be good for anywhere between 2-4 degrees improvement over anything else I've tried, even if it is a PITA to apply, and can short out your board if you splash or spill it.
Air conditioning. Drop your room temps, watch your system temps follow.
