Old May 2, 2009, 11:31 PM
kyle_L's Avatar
Default fan modding
is it safe to run 3 fans off one 3 pin connector. i want to make it easier to run cables and control the rpm.
Gotta Love Timmies Coffee.
Old May 3, 2009, 04:56 AM
dataxpert's Avatar
Each fan connectors support 2A max ( 24 W at 12 v ) , but the total the board will support is 7A ( 84 W at 12v.)
Now the question how much % of the maximum is safe
Old May 3, 2009, 08:52 AM
MpG's Avatar
MpG MpG is offline
You can run multiple fans off of one 3-pin connector, but as just said, you need to be careful about not taking too much power from the motherboard. The manual should tell you how many watts or amps the fan headers are rated for, and the fans should have their power/current draw written on them somewhere.
When connecting the fan wires together, make sure each fan is in parallel, and only let one yellow wire connect to the motherboard, otherwise you'll get incorrect rpm readings.
Old May 3, 2009, 10:24 AM
Cowboy's Avatar
What about when you use a dedicated fan controller? with 45w dedicated per channel?
Old May 3, 2009, 10:29 AM
Supergrover's Avatar
Yuor good as long as the combined watts of the fans isnt greater than the fan controller, in your case 45w.
I never run any fans off my mobo headers, less draw for the mobo.
Old May 3, 2009, 10:34 AM
Cowboy's Avatar
I totally agree! save the power for the OC I say!
and my fan controller is rated for a max of 45w per channel, and its got 6 channels.
Old May 3, 2009, 11:03 AM
kyle_L's Avatar
i forgot to mention that im using a bitspower fan board thing.
Old May 3, 2009, 12:53 PM
dataxpert's Avatar
Look at my reply , I get it from the manual....
Old May 3, 2009, 01:09 PM
MpG's Avatar
MpG MpG is offline
I wasn't sure if you were talking about that exact board or not, since not all motherboards are equal.
Old May 3, 2009, 01:26 PM
Should be fine then they just split it from a molex to a bunch of 3 pins IIRC.
Modding idea.. metalcore Water Cooling 9 January 6, 2009 11:06 AM
keyboard modding cmac79 Peripherals 2 September 26, 2008 11:43 PM
FS: fan hDD cage w/ 120mm lighted fan, cpu funnel, pentium 1 elninio Buy/Sell & Trade 7 June 20, 2008 12:18 PM
Keyboard modding chibi_man Peripherals 2 November 8, 2007 06:25 PM
X-Fi modding. turtletrax Audio 8 October 30, 2007 11:19 AM
