Originally Posted by Dwayne How is your cable management? There are lots of fans in that little case, if I recall. Have you tried the side fan as exhaust instead of intake? The ATI cards run pretty hot too... not sure of the 4890, I would have to read Sky's review again to see what he said on heat. |
I guess my
cable management is ok. I've tried both exhaust and intake for the side panel. CPU with Intake 47C CPU with exhaust 50C. I don't care that much about the GPU temp, it's more the CPU temp that bother me.
edit; that picture is with my 4850 wich I sold and got a 4890. anyway, cable management is about the same.
Originally Posted by dataxpert He have already 2 x 120 fan on the font of the case, where he will place is dvd with a Kama-bay ? Are your tri-cool fan running at high speed ? Are the I/O cover plate there, in that case you better to have them install |
Both tri-cool are exhaust and running at the lowest speed. The I/O shield is in place. And I know my case is not the best one for cooling but for $50 it's still a good deal. Might change it in the future too.
