Old April 25, 2009, 10:53 AM
Shadowmeph's Avatar
Default How do I wire the exhaust fan to a slower speed?
I built a older 478 box for my niece but the exhaust fan (which is 3 pin) seems to be running at full speed and is noisy is there a way to wire it so I can slow it down to reduce the noise?
Old April 25, 2009, 11:03 AM
stoanee's Avatar
Like this?
techPowerUp! :: Easy 7V Mod for Fans
heatware
Old April 25, 2009, 11:31 AM
Shadowmeph's Avatar
Originally Posted by stoanee View Post
Thanks I am going to try this it basically says that you switch the placement of the red and yellow wires
Edit it didn't work the fun doesn't turn on at all , oh well she is just going to have to listen to a noisy fan while computing lol
Old April 25, 2009, 11:44 AM
dataxpert's Avatar
:rtfm: WAIT A MINUTE
you have a 3 pins what Shadow refer you is for a 4 pins molex, on a 3 pins the yellow is the detector of fan speed.
Look in your Bios if you can set the speed of the fan
Old April 25, 2009, 11:51 AM
gingerbee's Avatar
or just use a resistor to lower the voltage
Old April 25, 2009, 12:50 PM
MacJunky's Avatar
Diodes work.
Old April 25, 2009, 02:16 PM
dataxpert's Avatar
Yes and it's more easy than too compute the resistor usally 1.5 drop per diode.
Originally Posted by MacJunky View Post
Diodes work.
Old April 25, 2009, 02:24 PM
MpG's Avatar
MpG MpG is offline
Depends on the diodes. Many common non-LED diodes actually come in at around 0.7V a piece.
If you've got a 3-pin fan plug, and the motherboard doesn't support voltage control, your options are somewhat limited without doing some recabling/rewiring.
Old April 25, 2009, 02:56 PM
dataxpert's Avatar
0.7 , Ya it's true, I mix it with the bridge, too longue time I have not use simple diode....
Is rear exhaust fan really needed? aviduser Cases 18 March 27, 2009 11:49 AM
fan speed problems phantom_jo Air Cooling 4 February 2, 2009 07:35 AM
320GB 7200.10 vs. 500GB 7200.11 (both SATA2) getting slower speed! DarKStar Storage 12 October 23, 2008 02:11 PM
Fan speed control serenity Troubleshooting 13 July 28, 2008 12:08 AM
Case fan speed!! Jarod_g29 Air Cooling 2 March 9, 2008 06:11 PM
