-   Air Cooling (http://www.hardwarecanucks.com/forum/air-cooling/)
-   -   Where can I find... (http://www.hardwarecanucks.com/forum/air-cooling/17015-where-can-i-find.html)
ImmaPC April 18, 2009 07:14 PM
Where can I find...
Those awesome-ly cool red LED fans like the one on the front panel of the CoolerMaster Cosmos S? It's pretty quiet, and I love the red color, I want to buy more but I can't find it anywhere!
go flames go April 18, 2009 07:58 PM
check the cm store on coolermaster.com
ImmaPC April 18, 2009 08:43 PM
I looked on the store and all I could find are these Red LED R4 Series fans. I also found this HDD cage w/fan like the one that originally came with it, but I don't need the cage I just want the damn fan!
Realityshift April 18, 2009 08:57 PM
Antec makes red LED tri cools that arent bad as well, not sure if you wanted that exact fan or just a decent red LED one.
NCIX.com - Buy Antec TriCool 120MM Red LED Case Fan 3/4 Pin W/ 3 Speed Switch - TRICOOL120MMREDLED In Canada.
JD April 18, 2009 08:59 PM
Also red LED Yates: Petra's Tech Shop and AC Ryan: Blackfire4 UV LED 120mm Fan Sleeved - Red
ImmaPC April 19, 2009 02:00 PM
Are the TriCools the same color as the CM Fans? I know they're both red, but like the same shade/luminosity red...
SugarJ April 19, 2009 03:33 PM
1 Attachment(s)
Get the red Yate Loons, I grabbed 4 of them. Made some brackets too.
ImmaPC April 19, 2009 08:30 PM
Wow, that looks sexy! The 2 fans on top are the Yates and the one on the bottom with the grill is the stock CM one, right? It looks identical!
Could I see a/some picture(s) of the brackets you made? Or should I just use velcro?
Realityshift April 20, 2009 05:24 AM
Probubly just tie straps to the optical drive mounts, atleast thats what I do when I wanna hang a fan where it doesnt belong =) as for your question about the fans, ive seen both in person and I couldnt tell the difference. I know the difference between CM blue fans and antec ones is pretty big but between the reds I couldnt tell the difference. It would be nice if NCIX would carry more then just the blue CM fans as I wouldnt mind some green ones and you could get your red ones. Yate loons are nice fans though =) Does petras ship to canada? I cant get the shipping gestimator to show what it would cost to ship to me =(
SugarJ April 20, 2009 09:07 AM
Sorry, missed this when you posted. All 3 fans are the Yates. Much quieter than the CM fans.
The brackets are the same as the one in this picture, just with a shorter leg. Just a piece of 1/8" aluminum flat stock.
Edit: And Petra's does ship to Canada, but you have to email them for a quote. I think it cost me $8 to have the fans sent by USPS parcel.
http://www.hardwarecanucks.com/forum...671e848ada.jpg
