Funny it was never mentioned or at least I thought so...
Arctic Cooling http://www.arctic-cooling.com/catalo..._090202_r0.pdf
If you follow
the news of the latest GPU system, you will know that we have a multi-GPU core for our
graphic card now. The main problem for graphic card is always about the “heat” problem. Lately,
Arctic Cooling presented a cooling solution for the dual-GPU graphic card such as AMD’s Radeon HD4870 X2. The name is Accelero Xtreme 4870X2 cooler. Here is the snapshot of this cooler:
It has a big dimension of 295 (L) x 96 (W) x 54 (H) mm and features several cool features such as:
- Extreme cooling performance up to 320 Watts
- 3 ultra quiet 92mm PWM fans with low noise impeller
- Efficient heat dissipation via 8 heatpipes
- Patented fan holder eliminates the buzzing sounds
- RAM and voltage regulator cooling
- Pre-applied MX-2
- Crossfire compatible
