Old April 11, 2009, 02:27 AM
somecanadianguy's Avatar
Default Coolermaster cm690 80mm fan...
Does adding an 80mm fan to side of the case (behind the CPU) affect temps much?
Old April 11, 2009, 03:27 AM
Realityshift's Avatar
Supose to take away a couple degrees or so, I wouldnt expect any miracles though your really only cooling the back of the mobo, and theres alot of PCB and plastic/metal between the fan and the CPU, no direct contact.
The Builders Hammer
Old April 11, 2009, 12:18 PM
I was thinking about adding a fan there, but I can't find an 80mmX80mmX15mm. I tried to find one with green LED's but to no avail.That's the fan size required on that case.
Old April 11, 2009, 12:20 PM
Soultribunal's Avatar
Hey Reality, believe it or not it does actually make a decent difference.
If you look at the Review done on the Speedo, the Fan blowing onto the motherboard was good for a 5-7 degree drop in temps.
So, yeah putting a fan there is a good idea.
I always thought it took a 70mm though...
ST
www.realhardwarereviews.com
Old April 11, 2009, 12:28 PM
I just checked the specs to confirm. It is an 80mmX15MM
Old April 11, 2009, 08:45 PM
Bones's Avatar
That's an odd-ball size, I don't think I've ever seen one X15mm ... Never mind one with green led's. If you could find one, I'm sure it would definitely help lower temps. It certainly wouldn't hurt.
Old April 11, 2009, 08:56 PM
try looking for a 60x15
Old April 11, 2009, 10:17 PM
JD JD is offline
80 x 15mm Fans : Performance-PCs.com, ... sleeve it and they will come
NCIX used to have a couple of those Hiper fans, but I don't think they do anymore.
Old April 21, 2009, 03:43 AM
I'll have to pick one of these up. As if I need more green light coming out of my case. I already have 3X120mm green led fans and a cold cathode.
Old April 21, 2009, 08:23 AM
Hmm thanks for the info ST, I think im going to have to try that now, already have 9 fans running in my case now whats 1 more... And thanks Jdrom I looked all over for one that would fit but gave up, I couldnt even find a regular black one let alone LED ones!
EDIT: NVM =( just remembered the xiggys crossbow mounting kit might be in the way and would probubly interfere with air flow =(
The Builders Hammer
GOOD 80mm PSU on the cheap death_hawk Power Supplies 3 November 8, 2008 08:55 PM
Drive bay fan in CM690 Infiniti Cases 3 August 4, 2008 12:23 PM
CoolerMaster Hyper212 Dual-Fan CPU Cooler Review Hardware Canucks Reviews & Articles from the Web 0 April 24, 2008 05:20 PM
Swiftech H20-220C + Coolermaster CM690 = Pump Noise! Arrgh! Nate_The_Great Troubleshooting 2 January 22, 2008 01:58 PM
80mm fan djnocide Air Cooling 7 December 30, 2007 08:43 PM
