Old April 5, 2009, 09:48 AM
Question Backplate question
Hey everyone.
I have a zerotherm nv120, and my backplate broke because i overtightened the screws. So now I'm stuck with Intel stock cooler. I've read that nv120 backplate is the same as Tuniq 120 backplate.
The question is, will Thermalright lga775bolt-through kit work with nv120?
Old April 5, 2009, 02:20 PM
JD JD is offline
Chances are any LGA775 backplate will work.
Old April 5, 2009, 03:18 PM
key to not stripping screws is just turn till u cant.. and screw the screws in with your fingers on the screwdriver not your hand. yes it will work btw
Old April 5, 2009, 04:10 PM
Thank you for your help :)
I dont think i tightened it too much. There reason i think it broke is because it was plastic.
Old April 5, 2009, 09:06 PM
biff's Avatar
I've always been told "tighten till it breaks then back off 1/4 turn". :)
i7 4790K @ 4.8GHz w/EK Supremacy Evo
MSI z97 Gaming 5
2x 8GB Gskill Sniper 2133 @ 2400MHz
EVGA GTX 280 (SC?)
OCZ Gamer Xtreme 600W PSU
Still rockin' the Cooler Master Cosmos on water
What is a good backplate compatable heatsink? Peppaaro Air Cooling 11 February 25, 2009 08:08 PM
Where to buy backplate mount for my cpu cooler? mailaw Air Cooling 4 January 13, 2009 07:39 PM
thermalright backplate owners Zippoh Air Cooling 3 December 15, 2008 07:05 PM
Backplate pad pulled off-how to replace it magictorch Troubleshooting 20 July 20, 2008 08:36 PM
WTB:Backplate I/O shield for an Asus A8R-MVP serioussam Buy/Sell & Trade 2 February 29, 2008 07:12 PM
