Old March 30, 2009, 10:49 AM
CMetaphor's Avatar
Quadfather
Originally Posted by SKYMTL View Post
I was making a point that where there is a will and a wallet, there is a way.
Corrected!
Old March 30, 2009, 11:09 AM
gingerbee's Avatar
ya no kidding you can make a pc with no moving parts not easy but can be done
Old March 30, 2009, 12:25 PM
maybe a submerged pc? with some big heat sink on gpu and cpu?
Old March 30, 2009, 12:28 PM
sswilson's Avatar
I'd be looking into itx format instead provided it would do what I needed it to do.
Old March 30, 2009, 12:51 PM
Cptn Vortex's Avatar
Stealth PC stealth is a manufacturer of fanless small pc computer systems and quiet and silent PCs
The Vortex H20
Asus X99-E WS/USB 3.0
i7-5820K
3 x GTX 1070
4x4GB Corsair LPX 2666MHZ
OCZ Z-Series GOLD 850W
HP OMEN 32 1440p 75hz
Benq W1070 Pojector.
Watercooling:
Old March 30, 2009, 01:13 PM
Just get a Mac Mini.
Old March 30, 2009, 01:34 PM
3 of 7's Avatar
If you were to build a pc with a vertical tube ( think chimney here ) I'm sure you could create more than enough airflow just by generating heat..
Anyone here ever smoke beside a table lamp? The smoke will get drawn a long way into the bottom of the shade by the airflow created by the 60w bulb.
Think about 2-300w of heat with a small diameter chimney above it.
Old March 30, 2009, 01:38 PM
gingerbee's Avatar
it's like you can read my mind
  #19 (permalink)
Old March 30, 2009, 01:48 PM
Hmm, thats an interesting idea... I think I might try this at some point...
The Vortex H20
i7-5820K
3 x GTX 1070
Watercooling:
  #20 (permalink)
Old March 30, 2009, 03:13 PM
gingerbee's Avatar
think direct touch heat pipe on all chips south north you get the idea
Moving to a new place, Should I take out my CPU cooler for moving? appplejack Air Cooling 5 March 10, 2009 02:44 PM
Moving sale everthing must go!!! Table21 Buy/Sell & Trade 18 February 14, 2009 04:18 PM
Moving to i7... S_G New Builds 5 January 6, 2009 06:19 PM
Moving a PC tom.mullie Troubleshooting 22 August 30, 2008 10:26 PM
Water not moving Infiniti Water Cooling 17 January 2, 2008 11:35 AM
